Results 1 to 3 of 3
Thread: replacing CV joint in tailshaft
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default replacing CV joint in tailshaft
    Well the tailshaft under me wagz is clunking pretty bad, it's all coming from the CV. So have bought a new CV and centre bearing (and will get new uni's as well)....but the only thing I'm not sure about is removing the CV. Does it have to be pressed off or do they come off easilly?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Come off easy. When you undo the allen bolts. Also, mark the shaft too and get it rebalanced.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Once you undo the allen keys you will see a circlip holding it on the shaft, been a while since it did it, pretty sure you then tap the boot off the back of the outer section and its slides off the shaft as a whole unit. They are a real prick to get back together right if the balls fall out on you, mine did it sucked. Then behind the cv joint is another circlip, take that off then the boot clamp and slide the boot off, youll figure it out its not difficult to work out.
  1. Replacing lower ball joint
    By commy92 in forum Holden Commodore How-To's
    Last Post: 27-12-2010, 09:47 PM
  2. Replacing mid Tailshaft bearing on 95 VS commodore
    By zapper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 10:32 PM
  3. Replacing A Ball Joint
    By Tibokan in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2008, 08:55 PM
  4. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  5. CV Joint
    By caldonia in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-11-2007, 02:50 PM
