Was washing some oil spilt from changing my oil today and i had the engine running as intended to just give it a quick hit under the oil filter and i splashed i little bit of degreaser on my coil and the engine instantly stopped, never had a problem with coils getting wet and failing before.
So i finished washing the engine and then gave the coil a good blow off with air, i didnt spray the coil any further with any water and it still had no go, so i tapped it with a hammer and it started to work again.
I have a Bosch GT40 RT coil that i could use as mine could shit itself at any moment i think, but the new coil says it must be used with a ballast resistor in the primary circuit. I was gonna use it on my Ute but i figured it would burn the points but the VK has no points so can i use it with out a resistor? Or will it burn out the coil or something.
And what is a ballast resistor/ what does it do?
wickapedia for ballast resistior - Electrical ballast - Wikipedia, the free encyclopedia
i had the same probelm in my vh simplest thing to do to fix it is put a peice of wire across from the battery to the coil and start it usually takes a few go
s but usually works just make sire ya put it on the positive side of the coil though lol blew a few up not doing this lol
I heard balance resitor is used in older cars. It stops any crackerling going through your radio. So depending on wat stero you got you may not need it.
