Results 1 to 20 of 20
Thread: what type of carby?
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Default what type of carby?
    Hey guys! just wondering if you could shed some light on what type of carby should i run? its currently running a 650dp holley! it seems like an overkill! any suggestions?
    this is how i had the VH 308 motor rebuilt!
    Block:Chemically Cleaned Bored 60thou Decked
    Heads: Ported, Big as can be fitted stainless steel valves, Flow tested 500-600HP
    Chemically cleaned
    Crank reground, Standard 308 rods
    ACL Flat top pistions, ACL molly rings
    Performance big end bearings, Performance main bearings
    Standard 308 push rods, Crane Solid Cam Grind no# cc-280-2
    Crane solid lifters, Dual row timing set
    High volume oil pump
    Engine balanced
    Elelbroc performer intake manifold
    High performance air filter
    Electronic ignition 'Holden'
    New mechanical Fuel pump
    thanks
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Properly tunded quaddy
    Scott
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    quaddys can be tuned for 50 horsepower 253's
    quaddys can be tuned for 500 horsepower 545's
    quaddys can save your grandmothers burning house.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    Quote Originally Posted by ari666 View Post
    really? IM COMING NAN!!! haha
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    That's if you know how to do it.
    On the other hand a 650DP holley will do the same trick and anyone with half a brain can tune them.
    ari666's Avatar
    1966 impala
    Mar 2009
    meh, only tricky part of a quaddy is adjusting the secondary metering flap, all the rest is exactly the same as a holley. in fact, there is probably less to think about with a quaddy, unless you want to push it to its absolute maximum. holley needs to have the right primary and secondary jets, powervalve, primary and secondary pump cam, pump shot, THEN the idle mixtures need to be adjusted, both fuel bowl needs to be adjusted perfectly etc
    quaddy is just bolt on, attach hoses, adjust idle mixtures, adjust secondary flap. drive. save fuel.
    Nov 2008
    Smithton, Tasmania.
    Can't say I've ever really had any Drama's with Holley's, that said. Quady's have always been scary and evil sitting on the top shelf in the shed. So I never bothered with them.
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Nov 2008
    Smithton, Tasmania.
    Quady that came from the factory.
    Apparently when done right they can flow something silly like 750-800cfm.
    ari666's Avatar
    1966 impala
    Mar 2009
    they only come in one size, they all can flow up to 730 and the biggest i have seen is 1000cfm
    edit* the biggest modified one is 1000
    VH SL/E 5.0
    Nov 2009
    Sorry to highjack but - I'm a fan of quaddy's too, but not really sure why! What IYO makes a quaddy a better carby over a holly?
    Nov 2008
    Smithton, Tasmania.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by DerekP View Post
    one word: rods
    [IMO] rods make for a much more efficient means of metering fuel, as vacuum decreases, the primary rods rise. they higher they rise the more fuel, then the secondarys flap opens as the air rushes past it, the more air, the further it opens and lifts the secondary rods with it. so fuel is metered perfectly, and air is metered as and when you need it, rather than holleys which are basically, here is WOT. whether you need it or not. (hey that rymes) and more often than not on our little 253's and 308's, we dont need it, in fact our engines often do better without that much air/fuel.
    ari666's Avatar
    1966 impala
    Mar 2009
    just so it makes a bit more sense, primary metering rods:
    secondary metering rods:
    as they lift out of their holes the gap around them gets bigger and allows more fuel through. pics copied from here: how to rebuild/ modify quadrajets (also vac hose diagram)
  15. #15
    Nov 2008
    Smithton, Tasmania.
    You can tune holleys to work better then that though,
    You jet them down, essentially strangle them and use different throttle cams and so on. Holleys are like bloody lego.
  16. #16
    ari666's Avatar
    1966 impala
    Mar 2009
  17. #17
    Nov 2008
    Smithton, Tasmania.
  18. #18
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
  19. #19
    Nov 2008
    Smithton, Tasmania.
    Don't think so, could be wrong but I think the Holley stud pattern is different.
  20. #20
    VH SL/E 5.0
    Nov 2009
    one word: rods
    Hence the term 'vacuum secondary' I assume? Thanks for that (I'm a little late on that I know!) - you're an absoluert wealth of information ARI, top bloke.
  1. swapping Jets from starfire carby to 202 carby
    By RippleEphex in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-06-2010, 02:01 PM
  2. Coolant? Type A or Type B
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 07:26 AM
  3. HELP!!! EFI Or Carby????
    By MY_84_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-04-2010, 07:24 PM
  4. Replies: 2
    Last Post: 06-04-2010, 02:53 PM
  5. VC/VH Carby
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-09-2006, 12:36 AM
