Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: wont crank!!
    VH SL 202
    Feb 2010
    Default wont crank!!
    ok heres my problem i bought a reco blue 202 for my vh and i got everything connected iv checked it lyk 20 million times and i bought a new heavy duty battery and it wont turn the starter kicks but it dosent wont to turn theres oil in it. 80% of the parts on it are brand new it did turn once but didnt wanna keep turning (basicly the motor isnt turning at all nothing moves just the starter motor making a klunk when u first turn the key to the *ON* position)
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    check the main wire to the starter. if you just power the solenoid itll clunk, but if the bolt is a little loose holding the main power cable the starter wont engage.
    VH SL 202
    Feb 2010
    VH SL 202
    Feb 2010
    ok i got it cranking and almost fired im pretty sure the firing order is rite 153264 or something its on the intake and in my book anyways i think it wont firer because of the vac lines dose anyone know where the one from the dizzy goes or evan if they know the layout where they all go would relli help
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    one from the dissy is the vacumm advance you can leave it disconnected for now it wont stop it starting. usually i think its connected to the inlet manifold at the back behind the carbie
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VH SL 202
    Feb 2010
    Quote Originally Posted by Pub247 View Post
    thanks mate
    VH SL 202
    Feb 2010
    hey everyone i finally got it up and running juns abit high and its sucking air lyk theres no tomorro iv gotta get the vac lines done then it should run alot smoother
    ari666's Avatar
    1966 impala
    Mar 2009
    VL V8
    Nov 2010
    perth wa
    Hey there have you tryed using a screwdriver on the pos and neg of the starter make sure ignition is on
    VL V8
    Nov 2010
    perth wa
    If that dosnt work put a socket on your harmonic balancer and try and turn manually make sure outta gear dse it turn?
    VH SL 202
    Feb 2010
    its all good the motor sounds like it runs smooth but there is one problem its blowing smoke not sure why i think the carb needs a good clean or tune there is one other thing aswell before i pulled the old motor out it was blowing smoke the same as this one. My motor now has new rings so im just thinking it could be the carb the fuel/air has to be out or something
    ari666's Avatar
    1966 impala
    Mar 2009
    brand-spanking new rings? if so its prolly just assembly lube/oil etc inside the chambers burning off. it'll take about 20 mins to go away.
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    new rings gotta bed can smoke 4 a bit while u get carbon deposits in your hone marks
    Making and running DUAL CHIPPED ECU SINCE 2010
    VH SL 202
    Feb 2010
    Quote Originally Posted by bloodyricho View Post
    yeh but this is pretty thick smoke
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
  16. #16
    VH SL 202
    Feb 2010
    Quote Originally Posted by ari666 View Post
    who re-ringed it?
    i bought it opff a guy that just recondition it
  17. #17
    UNDERCOVER HQ is offline HOT 202
    VN BERLINA 202
    Oct 2010
    townsville
  18. #18
    VH SL 202
    Feb 2010
    i just ran my car for 5 mins and its still blowing smoke i didnt try reving it i just let idle on its own not sure why its like this Anyone got some suggestions?
  19. #19
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    what colour is the smoke?
  20. #20
    VH SL 202
    Feb 2010
    its white smoke.. i was thinking of pulling the carbi off and cleaning it with carby cleaner
  21. #21
    vb sl
    Aug 2010
    mortlake
    yer blue smoke it oil eg rings or valve seals are rooted but white smoke is fuel so i think your on the money
  22. #22
    VH SL 202
    Feb 2010
    Quote Originally Posted by bjwynd View Post
    well ill give the carbi a good cleaning and see where what happens then
  23. #23
    vb sl
    Aug 2010
    mortlake
  24. #24
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    If its got an auto trans the vacuum modulator could be stuffed, which will let your engine suck the trans fluid out of your trans and burn it in your engine. Check that there is no oil in the vacuum hose that goes from your inlet manifold to the back of the trans. if there is oil in there then the vacuum modulator is stuffed.
  25. #25
    VH SL 202
    Feb 2010
    what carb is it a quady or vera jet
    its the standard vara jet
  1. vr wont crank over
    By minimefx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2009, 08:23 PM
  2. VX wont crank over
    By Mr Szu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2008, 01:01 PM
  3. vr wont crank over
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 11:56 AM
  4. VN V8 Wont Crank over when Hot
    By madA69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 11:42 AM
  5. engine wont crank
    By Michaelgreenaway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2005, 11:23 AM
