Results 1 to 2 of 2
Thread: help please exhust vc commodore
    vc commodore
    Nov 2010
    adelaide
    Default help please exhust vc commodore
    hi to all,
    i have 2 Vc commodores and im trying to make 1 really good car out of the two,i pulled off both exhaust systems and found all the best bits i put the exhaust onto my preferred car, but im having issues with the four studs that go to the down pipes,they are leaking air i have tighten them as hard as i can, any one done this job before that has any ideas ? is there some sort or sequence or knack to to the job? hope to hear from someone soon.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Did you use new gaskets? You will need two gaskets, a double gasket that goes onto the manifold under the butterfly, then a round ring type gasket that goes onto the pipe that is up against the manifold. Use silicone sealant on both sides of the big flat gasket and put silicone on each pipe. If you bolted them up dry with the old gaskets, they will leak.
    Visit my Facebook page
  1. Exhust
    By MAC-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2008, 08:51 PM
  2. Exhust help
    Last Post: 22-12-2008, 02:04 AM
  3. vn - vr v6 exhust manifolds???
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2007, 10:49 PM
  4. exhust help
    By reaper115 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-08-2006, 09:59 PM
  5. Vp Exhust system
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2005, 08:09 PM
