Results 1 to 5 of 5
Thread: help vk problem
    vk Executive 1985 wagon
    Nov 2010
    loch sport
    Unhappy help vk problem
    HELP im trying to install my cd player n i have got too connecter from the main wires that r the propa colours to install the wires im unsure wat to do n also wat mount can i use to keep my cd player in the middle PLEASE HELPPPPPPPPPPPPPPPPPP AM STUCK MAJORY
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    Heres the wiring colours, which should get you off to a good start
    Accesories - Yellow
    Constant - Orange
    Illumination - Grey
    Earth - Black/White
    Front Left (+) - Tan
    Front Right (+) - Light green
    Rear Left (+) - Dark Brown
    Rear Right (+) - Dark blue
    Are you replacing the speakers as well? If so I would really advise running new speaker cable for them, as the speakers in the VK's run a constant (-) which wont work so great with your new CD player.
    As for mounting your cd player, you need to get the sleve that came with it to fit in the hole, from memory you need to file down some of the plastic next to the a/c switch to get it to go in all the way, then you can ever rivit the sleve in or use the tabs on it.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    and dont forget that the newer players are load heavier than the original so to save the dash cracking best to mobify the original top rear bracket and fit that to the radio as well.
    Wiring diagrams are also on my site.
    Nov 2010
    loch sport
    Nov 2010
    loch sport
    um i have ran new wires from my speakers in the bk but the old one is still in the car so wat do i do with that one i dnt want to connect that up.. i want to use the new ones i ran....
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  3. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
