Results 1 to 17 of 17
Thread: VK v8 breathing problem/oil pressure problem
    Aug 2004
    Default VK v8 breathing problem/oil pressure problem
    Hi all,
    I am having problems with the oil pressure in my vk v8. When i start it the oil pressure gauge goes up to flat out and stays there, what would cause this? Is it the gauge maybe? It has a high volume oil pump on it, but i have run them before and they have never sat flat out the whole time. Would it have something to do with rocker cover breathing? Do both rocker covers need to have breathers on them? I currently have 1 small chrome breather on it, is that not enough maybe?
    Thanks in advance
    VH SL/E 5.0
    Nov 2009
    Aug 2004
    Ok i will replace that, anything else that could cause it? it has got me stumped! How do you know if your engine is breathing enough?
    RazzaCaine is offline Long Gone Now
    Mar 2010
    my oil pressure in the vb goes to near the top when i first start it for the day and hits the max at around 2500rpm, after about 10 minutes once its warmed up it sits just below the red zone. im assuming its normal as the oil gets thinner as it gets warmer, hence the drop in pressure
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is it a procomp high volume pump many of them blow oil filters to bits cause the pressure valve doesnt work
    VH SS
    May 2009
    Toowoomba, Qld
    how old is the oil pump ?
    I'd be checking the pressure relief valve operation in the pump
    engine PCV operation won't affect oil pressure, however it will damage the engine & seals if it isn't breathing properly
    Aug 2004
    Not sure of age of pump, how do you check that?
    Also do both rocker covers need a breather? I currently have one on the D/S front, just a chrome mushroom breather
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    One should be fine, the breather is there to release crankcase pressure so you dont have seals being blown out. make sure the breather is not clogged and is working, it would not have any effect on oil pressure however.
    vr v6
    Aug 2009
    Is it a mechanical or electric gauge?If it is electric the gauge could be earthing out.
    VH SL/E 5.0
    Nov 2009
    I still reckon it's your oil pressure switch. Process of elimination, start with the easy stuff first before you pull your engine apart. As VK SL 202 said check your breather valve but still this shouldn't effect oil pressure.
    *Edit* I should probably say sender rather than switch since you have an oil pressure gauge rather than a silly light.
    VB SL/E
    Dec 2008
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by Guzzoline addict View Post
    good point, if the circuit shorts to ground, the gauge will read max pressure
    To the OP, I'd suggest disconnect the sender unit wire from the sender unit and check if the gauge is still reading or drops out. If it still reads, then there is a short in the wiring.
    Also as suggested check the sender unit itself. It may also be at fault
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    why a high volume pump? all they do is pump oil into the rockers and suck the sump dry. unless you have done something to get the oil back in the pan i would be putting a stock pump back on.
    nevertheless, the earthed out sender seems like the right idea.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I have discovered today a weird thing with the oil pressure sender, when the wire to the sensor is left off it goes all the way over to the right, the gauge itself runs three inputs, + 12v a full earth and the variable earth from the sensor, and when left off or unplugged the gauge goes crazy. Took me ages to figure out cause i thought i had a short somewhere then a dodgy gauge, but then i went and unplugged my other Vks oil sensor and it did the same thing, it must require the variable earth to control the movement somehow.
  15. #15
    Aug 2004
    thats all good info guys, i have now got a new oil pressure sender and am changing it out tomorrow, hopefully all good!
    Thoe oil pressure relief valve was definatly not stuck on so it hopefully is the oil pressure sender. Will pull the wire off to have a look.
    Cheers for your help.
  16. #16
    VH SL/E 5.0
    Nov 2009
  17. #17
    Aug 2004
    Hi guys, changed the oil pressure sender and presto!! The gauge works like a dream, stoked!! Cheers to everyone for their help
  1. So here's my oil pressure problem..
    By Vee-ard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2010, 12:35 AM
  2. oil pressure problem???
    By defa in forum V8 Development and Modification
    Last Post: 25-04-2010, 01:19 AM
  3. V8 Oil Pressure Problem
    By N_Mitch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2008, 08:46 PM
  4. Oil Pressure problem on VP SS
    By ghd1996 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2006, 10:28 PM
  5. oil pressure problem i think ?????
    By krawczuk in forum V6 Development And Modification
    Last Post: 26-11-2005, 04:43 PM
