Results 1 to 7 of 7
Thread: rear brake lights vb sl
    vb sl
    Dec 2010
    sa
    Default rear brake lights vb sl
    Hi, just bought a vb sl rear lights were working when i picked it up but not once got home checked all the fuses n light bulbs can see any fault, any suggestions???
    vb sl
    Dec 2010
    sa
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    so your brake lights arent working??
    check your brake light switch on your brake pedal
    scott
    vb sl
    Dec 2010
    sa
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by vkberlina View Post
    scott
    Take a can of WD40 with you while you're under there.....
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Had exact same issue in my VB, although the tail-lamp failure was intermittent. Check the bulb holders for corrosion, and check the wiring for condition. On mine, both these areas were shot, the right hand light had some bodgied up fix for some reason. Got good condition replacement from the wreckers for $10. Even if one side is shorting out, it can effect both sides for some reason, as I found out. The bulbs need proper bulb holders for proper earthing etc. hope this helps
    RazzaCaine is offline Long Gone Now
    Mar 2010
    [QUOTE=c2105026;1719760]Check the bulb holders for corrosion, and check the wiring for condition.QUOTE]
    +1 my left hand brake light and indicator werent working as the contacts where the wiring clip connects had rusted out. i wanted to fix it asap but the wreckers werent open today so i cut the wires before the clip, extended the wires with some new wiring and soldered them directly to the contact on the bulb on the side that hadnt rusted out. hey presto they work fine now
  1. brake lights not coming on until brake pedal almost to floor
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2010, 07:11 AM
  2. vh rear brake light and reverse lights not working
    By ovc762 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-06-2010, 09:26 AM
  3. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  4. Electrical Gremlins- Brake Lights And Head Lights
    By xxNoblexx in forum Electrical Wiring / Questions
    Last Post: 10-02-2009, 09:59 AM
  5. Both my tail lights and brake lights have stopped working.
    By stuballs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2008, 11:35 PM
