Hey all,
I have a vk that is efi and won't go ATM I've checked the fuel pump n it's pumping right up to where it goes into the injection rail what else can I check to see what's going wrong because it kinda coughs like it wants to start sometimes
Thanks Matt,
MY VN 88 EXEC
http://forums.justcommodores.com.au/vn-vp-vg-vq/89493-my-first-car.html
Check for spark, power at coil ect. see if fuel is coming out the return line to be sure it getting pressure, that works unless the fuel pressure regulator has packed it in. will it start on aero start ect. Check a few things and get back to us![]()
I'll check for spark tonight is the return valve at the end of the injector pipe with the value that looks like a car tyre one? Coz I pressed that and fuel squirted out
MY VN 88 EXEC
I'd check the tachometric relay in the fuse box. Well not sure how to check it, maybe just borrow one off someone and see if that fixes it.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
