Results 1 to 4 of 4
Thread: VS elec windows into VK. Can it be done?
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Default VS elec windows into VK. Can it be done?
    Iv been doing some research for awhile to put my VS elec window set up in the VK. Basically what iv learnt is that the VS set up goes into a LX torrie and their also similar to the VL. Saying that VK and VL are simular.
    So from my basic understanding the fronts have no problems going in. Its the rears i could not figure out!
    Would anyone have any info or know anyone that has done it to shed some light? Because if it could be done im keen to do it
    Cheers in advance.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I would think the VS ones wouldnt fit the front as the doors look bigger on the VR/VS, you would need to measure up the doors and see if they would fit, as for the rears check the travel height and if the same it should be able to be done the rears are a bitch with the wire cable looping all through the doors, I will never pull mine out again.
    Propably with a bit of fiddling and adapting they would be able to be fitted but why not just use the factory VB-VL ones that would just bolt in?
    scott
    VS
    Jul 2010
    Cheers for the info scott. Im aware of it being a hard time, but being summer i like atleast from front windows down and leaning over to do the passenger side can be painful at times.
    The reason im using the VS ones is because im wrecking my VS. The elec window set up is near imac and instead of going out to buy some used possibly stuff set ups i have my VS ones still in the car.
    Im thinking i may have to buy a front and rear door and do the test fits on them. But theres no point in going to all the trouble if they dont even want to fit in the first place.
    D22 St-r Navara
    Dec 2010
    perth
    i think its pretty close with the front mechs from memory just go on egay and compare visually
  1. elec windows
    By Thorny32 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2010, 11:46 PM
  2. Elec windows price
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2006, 12:40 AM
  3. vs ecotech motor+auto,vq statesman rear seat, elec windows, elec arials more
    By wizza in forum Parts And Other Items For Sale
    Last Post: 06-06-2006, 11:22 AM
  4. elec windows
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 10:56 PM
  5. elec windows
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2005, 07:19 PM
