Results 1 to 11 of 11
Thread: Does the flywheel need to be a certain way on a VK Black motor?
    toxic VL is offline Project VK begins
    85 VK
    Dec 2007
    MARY'HOLE QLD
    Default Does the flywheel need to be a certain way on a VK Black motor?
    Hi All,
    I am having major problems getting my Auto 6 EFI VK running, I put in a fresh motor and everything seems to be how it came out, but when I'm trying to get it started it just does not run properly if at all. I have done the timing as instructed by some of the awesome tech post's on here and another site but I am thinking the flywheel may be out?
    Is this right does anyone know? Also I'm hearing the speed sensor could be an issue? I have looked on my box and it didn't have one when I pulled it out........ Very confused.
    Any help would be fantastic,
    My other lover is my VK
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Ummm, auto? It would have a flex plate not flywheel.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Only EST carby vks ran the cas sensor on the flexplate efi use a hei dissy to pick up signal
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The EFI 6cyl run a prehistoric injection system, make sure your fuel pump is working first as it runs of a tachmetric relay that only activates when the engine is above about 200 rpm and are common to fail. Press the valve on the end of the fuel rail to check for a bit of pressure is there. As said it doesnt have a CAS sensor, only the EST versions which are on the carby 202's use it. Just run over all your sensors and make sure they are all plugged in, if i remember right it has a throttle position sensor, a mas air flow sensor, a coolant temperature sensor and an auxiliary air valve somewhere. Im pretty sure it also has a wire to the coil or dizzy so it knows engine speed as well.
    Spray some aero start in the intake and see if it gives a kick then you know its the injection side, if not check your ignition system for good spark ect.
    85 VK
    Dec 2007
    MARY'HOLE QLD
    Sweet as, thanks for the info everyone.
    It runs sometimes after i've reset the timing but it sounds like it's not firing on all cylinders and backfires a crap load, so i'll check all sensors and stuff in the morning and give it another go.
    Cheers again.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    hace you removed your dissy lately sounds like it may be 180 degrees out
    85 VK
    Dec 2007
    MARY'HOLE QLD
    yeah tried the right way and then the 180 degree but still won't run properly, I'm thinking if i just replace all injectors, leads and spark plugs and get a new coil, that should fix the issues i'm having, if not atleast i won't have to buy them later.
    85 VK
    Dec 2007
    MARY'HOLE QLD
    ALL IS AWESOME!!
    Thanks for your help everyone, it turnsed out to be the timing marks on the balancer we're way out thus not being to line it all up properly, she purrs like a kitten now so cheers
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Change your balancer, the outer hemisphere has moved from the inner one and will let go in not to long, it will either slide in like mine did and hit the timing cover, or if your unlucky slide off and go through the radiaitor or god knows where else. Your belts will all get noisy and squeaky if it decides to move. Not a pleasant noise let me assure you.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah they make horrible noises when they dissapear under the car at 100kmh LOL
    85 VK
    Dec 2007
    MARY'HOLE QLD
    oh crap lol, no worries man thanks for the tip, I'll change it out now.
  1. black motor
    By diesellandyman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2009, 03:15 PM
  2. 308 black motor
    By elegance in forum V8 Development and Modification
    Last Post: 28-11-2008, 11:20 PM
  3. little help please 3.3 black motor
    By 305holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-07-2006, 10:32 PM
  4. VK Black Motor
    By Morgasshk in forum Parts And Other Items For Sale
    Last Post: 20-09-2005, 08:15 AM
  5. EFI for black motor
    By mark 70 in forum Parts And Other Items For Sale
    Last Post: 05-04-2005, 05:10 PM
