I was recently defected for "bonnet structure weakened by hole" (among other things). I'm just wondering wat the models which had the scoop done for a bonnet? If they had to be legal, how did they get around having a hole in the bonnet? Or didn't they have one?
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
I don't think there was a hole in the bonnet, the scoop was just for show - on the VH's anyway.
Some VHs had them, the ram air HDT option on Brock VHs.
care to post a pick of your hole in the bonnet?? inside the bonnet and outside?
scott
Yeah I cut the frame. Haven't got a pic of the bonnet with no scoop tho. Yeah haven't painted under the bonnet, was in a hurry lol.
yeah nah I reckon you'd have been ok if it was just in the skin, but the strengthened part..
btw, i read the title and thought you were talking about homer simpson speed holes lol
I'll be interested to see how this pans out, will be in the same boat soon.
What else ya get ya on Danny?
I had to cut a similar hole in my bonnet to fit the manifold.
the 'frame' you have cut is just the skin support (notice it's a lot thinner than the main bonnet supports) It's not the main bonnet frame
As correctly pointed out, the VL Walkinshaw had the same frame cut
If you had cut the main bonnet frame, then it would be a different story.
If you get too much grief, just attach/weld a couple of similar gauge support beams either side of the hole.
danny8, I've done it to my vh with the hornet scoop, I do get some weird looks from the coppers,The rubber strip thats on your flywall get a spare one, put it around the hole so theres NO sharp bits, I hope this helps you, Cheers Jason
MISSING
WIFE AND DOG
REWARD FOR DOG!!
Thx guys. I might ring the guys at Regency and see wat they say, maybe they'll have no probs with it then.
Staggie, got done for the hole in the bonnet, Holley, surge tank in rear of wagon, aftermarket cam (check), 20" rims fitted, pressure line (fuel) gauge to be removed.
Bout the fuel line bit, he said the adjustable fuel reg had to go. If the motor makes enuf power to need one then it's not legal apparently. But from how he's worded it, it sounds like he means the fuel PSI gauge so will just remove that temporary. I think that's a load of bollocks too, will see wat the Regency guys say.
Got a 253 ready to drop in. Using VN heads on it (don't have to change my extractors then either) with a stock EFI cam, and also got a quaddy on top.
Not sure wat else they'll pick up on. I know it won't pass first shot tho...but I have heard of old banger Commodore's passing first shot so maybe it will. All the normal worn out stuff they look for (seatbelts, bushes, brakes, suspension) is all brand new still.![]()
in qld okay to cut skin but not the support and the scoop cant just be fibreglass has to have a meatal inner skin bolted to bonnet
sounds ####ed but no that hard to do!
how did u get defected for the cam? did the cop have an emissions tester with him or just heard it idle and assumed it was cammed and wrote up a defect to suit?
since the emissions rules back in the vk days were not real strict u might have a chance at passing the sniffer test with a decent rotchester bolted on top, so long as the cam isnt too crazy
Just brace it.
I'd be ringing regency and double checking it all, cant see how a fuel pressure gauge isnt legal, although where abouts is it?
Sounds like the cop sorta knew what he was on about, holley, 20's and surge tank is understandable.
Lol hurry up and get VN heads would ya! Apparently 150rwkw shouldn't be to hard to hit with VN heads on a 253. But won't aim that high with the stock cam.
The cop asked me wat cam was in it, I said stock, he had a giggle and put pen to paper lol.![]()
The 253 has a stock EFI cam so I'm hoping it will pass easy.
Yeah I can't understand it being illegal either. It's mounted to the pressure reg, which is bolted to a bracket which is bolted on by one of the strut mount studs. It's on the driver side strut tower, ya can see it in the pic above.
Who did you for it in Pirie? I used to live up there lol
give a local automotive engineer as call and make a time to go and see him to get it certified.
Ask the engineer what he wants to see to have it pass ADRs
Complete the work and return to him.
Other option is to delete the centre support completely inject some urathane where the cuts are to look like normal glue then paint the inside of the bonnet, done properly you wouldnt pick it from factory
scott
Dunno if replying here is still relevant or if the issue got resolved but my mate's VK had a hole in the bonnet for his filter to stick through & he also had a scoop which just bolted/unbloted to the hood & the only reason he got defected for the hole was because it needs to have a solid rubber ring around the hold, as in, a big O ring, not just a straight bit from clark rubber bent around into an O, but that was a few years ago here in QLD
