Results 1 to 6 of 6
Thread: VB Fuel Pump problem. no fuel getting to engine.
    vb commodore sl 1979
    Dec 2010
    nsw
    Post VB Fuel Pump problem. no fuel getting to engine.
    i have a vb commodore as a paddock basher, recebtly just stoped, and it is not pumping fuel to the carby or the fuel filter.. where are the fuel pumps on these? are they in the tank? how to go about replacing one? if taht is the problem which im sure it is.
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    filters are next to the pump ..which is on the side of the engine
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    Dec 2010
    nsw
    vb sl
    Aug 2010
    mortlake
    there on the block follow the fule line down there is two bolts holding them on
    Dec 2010
    nsw
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The fuel pump is bolted onto your engine and has an arm that runs on the camshaft to operate the pump. It is on the drivers side just in front of the engine mount and is held on by two bolts. You might have a stripped cam gear too. If the teeth are stripped off the cam gear which is very common then the cam wont turn so the fuel pump wont pump. Take the distributor cap off and wind the engine over so you can see if the rotor button is turning around like it should. If the rotor isnt turning then your cam gear is probably stripped.
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. Fuel Pump Problem
    By W1LLO in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-08-2010, 10:17 AM
  3. possible fuel pump problem? please help!!!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 04:54 PM
  4. Fuel Pump Problem?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:46 PM
Tags for this Thread
