Results 1 to 6 of 6
Thread: Seating Arrangement
    VR Commodore, VK EFI 5.0 Calais
    Nov 2010
    Mount Gambier
    Default Seating Arrangement
    hey all, Just wanting to know if vy calais seats and door cards would fit into vk calais, vk pews very ordinary, ciggie burns etc Thanks
    Nov 2010
    Mount Gambier
    efi 202 torana, vk project car!
    Mar 2010
    mount gambier sa!
    Seats would be doable. Won't bolt straight in but bit of tinkering using the vk mounting thingy bit lol can't think what ua call it. The door card prob not so easy. Prob be dif size and the holes for like window wipers and handles etc. Well that's my 2 cents worth. Personally I'd either hunt around the wreckers for some better condition seats etc or if i was made of money get the interior redone.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Neither fit. Although some have used a bracket. With that, you need an engineer cert.
    chooky1980's Avatar
    chooky1980 is offline Donating Member
    vh sl/e,vk berlina
    Nov 2010
    deniliquin
    anything's possible.just have to work it all out,with me i work it out as i go.i have fitted a vn dash in a cortina,vs door trims,dash and console in a hq ute and other out there stuff.i love making something work when it's not meant to.as previous posts said the seats are not that hard,the door trims however would require a lot of work.especially where the trims meet the dash.you have power windows so winders wouldn't be a problem.door handles-you would use the vy ones.scuff plates and pinchwelds-you would have to have the proper clearance so the doors shut properly and don't crunch on them.there are many things to consider but it is possible!! cheers
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    as for door trims,your best bet would be to recover factory cards in same/similar trim to match the seats. retrimming door trims is easy
    scott
  1. VS Ute Seating Question
    By matthewmckay231 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 10:41 PM
  2. VS T5 speedo arrangement different to earlier T5's???
    By LX_HATCH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2010, 04:16 PM
  3. Vx Berlina Audio Arrangement
    By bennzy in forum Car Audio
    Last Post: 26-06-2006, 10:46 AM
  4. spring seating
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2006, 09:18 PM
