hey guys just wondering if the vk carb motor will fit straight in with my 5 speed borgWarner
yeh man. straight in but vk will have EST if its original and you need to put in a blue motor dizzy instead to get it to work without a computer and probably blue motor carbie to get the correct vacuum for the dizzy, or you can use the ported vacuum off the EGR valve pipe if you use the vk carby, they are the same carby but vk has deleted the dizzy vac port just to be a pain.
just use your manifold and carby off the blue motor and swap over the dizzy from the blue motor the rest is just straight in.
