Results 1 to 5 of 5
Thread: Alternator
    commodore vk auto 3.3 everyday car
    Oct 2009
    Default Alternator
    I am running a stock black 3.3 with air con and spotties at night (country ) and the battery is less than 12 months old the same as the new alternator.It seems to run ok and when I put the multimeter across the battey while idling it reads 13.7.After not using the car for almost a week the battery went flat while cranking and I had to use jumper leads and she started.The car will start every time if used daily or every coule of days.
    The instrument guage is either on 12 or below when driving with air con on.How accurate are the guages?
    Do I need to get a beefier alternator or can the one I got 22/55 14v be modified to increase output?
    Dec 2009
    Quote Originally Posted by commy vk View Post
    13.7 volts means it is charging. Do you have any load on the battery while the car is not running? You can check this with an amp meter as this is probably the cause, other than that the battery can drain through the alternator if some of the diodes are shorted.
    Oct 2009
    Can a immobiliser drain the battery after sitting for a while?....It just has the flashing light running.
    torch is offline Banned
    vz
    Dec 2010
    carrum
    You have a multimeter, you can assess how accurate the gauge is using that? Put your air and lights on rev it to ~2500rpm and measure the batt voltage with the multimeter and compare to your dash and you'll have a baseline for cruise and idle.
    the two numbers 22 and 55, represent basically idle output and full output. If you at idle with all your lights on etc and air, you'll probably be draining the battery, but 55A should be fine for cruise. The aircon itself(compressor clutch) shouldnt create any substantial electric load, is there an electric condensor fan that switches on with it and stays on even at cruise?
    Flashing lights depending on their current draw will eventually drain the battery, a couple of days = fine, couple of months can be touch and go if the flashing led is an older high current consumer.
    Oct 2009
    Thanks for the reply guys,yes it does have the cond fan running when air is turned on.
    That will explain where the power is going....Cheers and Happy New Year.
  1. VE V6 alternator
    By cds in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-01-2010, 11:53 AM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. alternator
    By DARK SIDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2008, 10:05 AM
  4. Alternator going?
    By squidda in forum Electrical Wiring / Questions
    Last Post: 29-03-2006, 06:35 PM
