Results 1 to 5 of 5
Thread: 202 Red Info
    Holden
    Jan 2011
    Aus
    Default 202 Red Info
    Does anyone know if a 202 red motor Crank case, sump and exhaust manifold will fit up to a Vk Efi 3.3
    As i have a marine kit for a red motor, Dont want to buy the motor then realize they wont fit.
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    crank case and sump, they should fit.If the sump out of a HQ you going to stick that in a vk it won't fit. but the exhaust manifold only fit 9 port head to a 9 port head, as same as 12 port head to a 12 port head. As for marine kit i don't know.
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    efi 202 torana, vk project car!
    Mar 2010
    mount gambier sa!
    Holden
    Jan 2011
    Aus
    Thanks for the reply, Looks like im going to be doing some welding In a boat you flip the motor and drive directly from the crank, so a stock exhaust manifold will face in the wrong direction. I THINK
    Cheers again
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    yerp exhaust is wrong for marine , sort of, a red manifold can have the exhaust face any direction really but all 12 port head manifolds have the twin pipes coming off im fairly sure, and they cant be easily made to face other directions but youll be having to make custom pipes anyway so it would be possible. my uncle has a 202 in a boat, its the wierdest looking thing. unless your looking at a fairly small boat nothing less then a 308 will be suffice, and even they are a bit underpowered, most go for the good ol 350 chev
  1. Excellent Info on REbuild for L36 or L67 Great info...
    By vxcalais_01 in forum V6 Development And Modification
    Last Post: 22-05-2010, 12:26 PM
  2. need some info
    By andyvs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2009, 11:08 AM
  3. info about PS3
    By SAV_117 in forum The LAN Lounge
    Last Post: 17-01-2009, 10:43 AM
  4. looking to buy a VS, need some info about them
    By oboc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2008, 12:48 AM
  5. useful VL info
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-03-2008, 09:10 AM
