Results 1 to 7 of 7
Thread: VH 308 carby to inlet manifold bolts??
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    Default VH 308 carby to inlet manifold bolts??
    hi guys, the tool that had my car before me, stripped the bolts holding the quadrajet on, and i rebuilt the carby, and now i cant put it back on cause the two front bolt holes are screwed......,
    the left hole had a bigger bolt put through by the looks of it he also drilled the carby out to fit the bolt through aswell, the other bolt is stripped and wont screw in, and i cant fit a bigger bolt into the left hole on the carby without drilling it out, which i am definately not doing.
    if i get a thicker bolt, with enough length to stick out of the top of the carby from the inlet, tap a new thread slightly bigger into the inlet manifold, put the bolt on a lathe, make a thread that fits the manifold on the bottom end, then machine the bolt thickness above the thread that goes into the inlet small enough to fit through the carby and put a smaller thread on top? i dont know if you guys get what i mean, i can draw up a diagram later if its not understandable
    i dont think theres much that can go wrong but last thing i want is to crack my manifold or something and have fun taking it off.....
    any other ideas please share, want easiest fix possible but not dodgy
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    easy fix...get a machine shop/engineering place to put helicoils in
    then all back to normal (you keep manifold and Quaddie bolts on normally)
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    vn_v6's Avatar
    Aug 2009
    victoria
    the quaddies hole has been drilled.....and how much would that cost me?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    I can fix it for you. $50 +postage?
    Has the manifold been opened up at all?
    Can do that too...
    vn_v6's Avatar
    Aug 2009
    victoria
    not taking the manifold off.....just said before, soooo the postage must be putting urself in a box and coming over here?:P
    Nov 2008
    Smithton, Tasmania.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    simple fix if you cbf spending any cash: get a bolt, grind down about 15mm of the thread so it tapers. then get a 2mm cutting wheel on the angle grinder and cut two deep grooves into the bolt along the length, one on either side. congrats, you have now made a self tapping bolt. tighten it up and never ever take it off again
  1. l67 inlet manifold
    By Adrian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2008, 12:46 PM
  2. vs inlet manifold
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2008, 12:49 AM
  3. inlet manifold
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2007, 09:52 PM
  4. WTB-(SA only)V8 prepollution inlet manifold OR 2BBL WW Stromberg carby
    By NOGEN 3 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-07-2006, 04:44 PM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
