Results 1 to 10 of 10
Thread: VK Elec antenna mast, is there a replacement avaliable?
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    Default VK Elec antenna mast, is there a replacement avaliable?
    Hi guys, posted this in the car audio thread but got no joy out of it so maybe someone in here knows.
    Does anyone know if there is a replacement mast available to suit a vb-vl elec antenna, don't particularly want to go thru the hassle of replacing the whole unit and having to take most of the dash apart. The rope on mine is busted.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    for starters you dont have to pull most of the dash out actually barely any of it
    Remove the inner guard
    Remove the kick panel
    remove the under glovebox trim
    Undo the screws fitting it & and mast nut and remove 30min job max
    your best bet would be an after market semi auto antenna
    cheers
    Scott
    Jul 2005
    Cheers Scott, I was under the impression that the antenna cable ran over the glovebox, although can't exactly remember, has been a few years since I've done one. Getting to the back of the radio will be the fun part from what I remember with the stock items.
    VB SL/E
    Dec 2008
    Jul 2005
    VB SL/E
    Dec 2008
    so you need to remove the radio to disconnect/re connect it then feed it thru the firewall.
    VH SL/E 5.0
    Nov 2009
    You might be able to get behind the radio to pull the antenna cable through the speaker cover on top of the dash, assuming the VK has one those....
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    forgot about the antenna cable, you can undo it from behind the ash tray if your good, one tip with the antenna cable, tape a draw cable to it, pull it back then when you fit the new antenna, pull the cable through.
    cheers
    Scott
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    cant you just remove the antenna from the guard, cut the old antenna cable, install the new one and tape the new cable to the old one and just pull it through using the old cable?
    VB SL/E
    Dec 2008
    Yep, I think the point is the dash does not need to be removed.
  1. VK elec antenna replacement mast
    By Staggie in forum Car Audio
    Last Post: 11-01-2011, 12:34 AM
  2. New Antenna and Mast
    By Paytz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-05-2009, 11:42 PM
  3. VY antenna mast
    By hit2407 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-05-2009, 03:28 PM
  4. VY 2003 model Antenna & mast
    By sebastian60 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-11-2008, 07:33 PM
  5. Power antenna mast
    By SLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2006, 01:26 PM
