hi guys can someone please tell me why my hazards dnt work ages ago i put a supercheap boss kit on n sport steering wheel on n since in my hazards dnt work how do i fix it n wat way does the boss kit go on if i have to take it off.
do your indicators work?
What have you checked?fuse or what just give it the general once over in the fuse box then if you done that and all not good then post again maybe someone can help after that, cause you might have earthed something out you shouldn't and the broken fuse might have saved you so check that out 1st.
the fuse is fine n my intercators work im really stuck on why it doesnt work please help
you know what you have done wrong! you fitted a boss kit. what you need to do now is undo everything you have done till you find the broken bit.
