Results 1 to 17 of 17
Thread: passing a RW(road worthy)
    VH SL 202
    Feb 2010
    Default passing a RW(road worthy)
    hey guys
    ill be soon geting rwc for my vh im pretty sure it will pass apart from 1 or 2 things like the rubber bu that goes over the front shocks apart from that im pretty sure its all rite and i beleave the other thing is the unis on the tailshaft i no there ####ed would anyone have any other info on what mech look for when getting a RWC
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I was going to write what to look for but honestly the list is huge, they go over pretty much anything.
    Seeing as you are in VIC you pay to get it checked at a mechanic, then he will give you the list of what is wrong with it and you have 14 days to fix it and take it back for him to pass it.
    From memory it was about $50 there 8-9 years ago, not sure how much it would cost now.
    Best RPG ever
    HJ premier
    Jun 2010
    Rust
    any leaks from engine, trans, p/s or diff.
    movement and cracks in rubbers eg. sway bar, control arms
    horn, lights, indicators, highbeams
    loose parts in the engine bay
    scrappy looking wiring
    and also they don't like unfilled speaker holes in the doors
    thats all i can think of atm just make sure u give the under of the car a good clean before you go so there's no build up of grease and oil, then you should be okay
    VH SL 202
    Feb 2010
    Quote Originally Posted by 75hjprem View Post
    Rust
    yeh thanks buddy i no theres no leaks at the diff or trans n motor and the rear end has got nolathane bushes and iv replaced all the ones on the front and atm my doors are fine
    VH SS
    May 2009
    Toowoomba, Qld
    HJ premier
    Jun 2010
    probably check your P/S rack they always tend to be leaky on vb-vk unfortunately
    unless yours is a manual rack.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Shocky boots probably arent a fail, but the bump stops may be, my Vk had neither when i registered it in NSW without a worry.
    VH SL 202
    Feb 2010
    yeh mate myine dosnt have the pw steering rack dont need that crap
    VH SL 202
    Feb 2010
    Quote Originally Posted by VK SL 3800 View Post
    yeh i think my shocks are origanal not sure lol but the car dosnt bounce like a ball tho iv seen a vl that u could push the front down and it would keep bouncing for 2-3 mins
    HJ premier
    Jun 2010
    haha my rear end was like that in my old vk, mostly because it had no panhard rod :P
    from the looks of your car mate you shouldn't have any trouble let us know how it goes though.
    VH SL 202
    Feb 2010
    yer no worries mate
    VH SL 202
    Feb 2010
    HJ premier
    Jun 2010
    a high pressure hose will work fine
    steam cleaning is better
    even just wipe it all away with a rag and hose it down should be fine.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Just any oil leaks, balancer and bottom of bell housing especially because thats where they always leak. then check your extension housing seal on the transmission and your pinion seal on the diff.
  15. #15
    VX SS
    Jul 2005
    East of Melbourne
    They check lots of things, some testers are ok others go overboard, but a few things that have not been mentioned on this thread yet...
    Brakes - Rotor thickness and condition of pads and hydraulics.
    Safety belts - freyed edges etc.
    Windscreen for chips and scratches, condition of wipers.
    Pedal rubbers.
    Lights/horn/indicators and that the indicators self cancel.
    Tyres.
    Modifications, lowering, different wheels if either are excessivly over done.
    Exhaust - Noise level.
    Door locks/Window winders all work.
    Dash lights/ speedo working.
    Rear vision mirrors not damaged.
    Handbake holding.
    Auto trans park working and not being able to be started in gear.
    Seats securely mounted ie not loose.
    Window tint if the car has it.
    Bonnet catch holding when bonnet popped.
    Faded taillights/indicators.
    Probably a lot more but a few things to check before you go. My sons have gone to some RWC places and they have done a very basic safety check, they have gone to others who have been buggers and picked the car to pieces. One we used but never went back to wanted a new petrol cap as he reckoned it was not venting properly.
  16. #16
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by TY318 View Post
    anyone got any ideas on what i should clean under the car with
    tooth brush?
    also: are your tyres placarded? looks to me like they might be a little bit bigger than stock.
  17. #17
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Mine passed with ####ed shocks, shock boots, p/s leak, broken seat belt.. Etc etc
    It's really who u get to do it..
    Put some 14s or 15s on with good rubber. Chek Ur brake disks and pads
    Widscreen glass!!!
    All your lights work
    Give Ur whole car a good clean before u take it in too.
    And don't spray degreaser around the dizY.
  1. Road worthy after defect. Advice please.
    By Patti2912 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2010, 11:12 AM
  2. [VIC] Dodgey Road Worthy
    By SikVP3 in forum General
    Last Post: 05-01-2010, 09:41 AM
  3. road worthy cert
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-10-2009, 04:29 PM
  4. Road Worthy
    By MG's VH Wag in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2008, 06:31 PM
