Results 1 to 9 of 9
Thread: Whats the diff between solid n hydraulic cams
    VH SL 202
    Feb 2010
    Default Whats the diff between solid n hydraulic cams
    hey guys
    i was wondering what i could do with my 202 and i was thinking of doing a cam but im not sure what type of cam to put in it and thats when i saw there was hyd and sold cams but im not sure on what the difference is... can they both be put on a std 202
    vb sl
    Aug 2010
    mortlake
    You can run solid cam but you need solid lifters and there noisy
    look at the bloke on your left now look at the bloke on you right now look at your self 2 out of the 3 people you just looked at are dead sh@ts which one are you
    commodore vk auto 3.3 everyday car
    Oct 2009
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Great answers so far people... NOT!!!!
    A solid cam, uses a solid lifter. Its pretty much just a round hollow chuck of metal. The lifter rides on the cam lobe and the cam lobe moves lifter up and down. A solid cam needs a lash setting, a space between rocker arm and valve stem
    A hyd cam uses a lifter that is like above but also has a spring and plunger inside it. The lifter fills with oil and pumps up. On adjustment, no slack or space is needed between the rocker and valve stem as the lifter bleeds off and pumps up with oil to chusion the valve train.
    Solid cams do not "hit harder" or run rougher then a hyd cam. The cam duration and LSA is what causes a cam to sound wild or mild. Both a solid and hyd. will and can sound rough or smooth based on the size of it.
    Yes a solid cam is louder running. It has a noticeable click. Kind of sounds like a sewing machine running, again thats due to the slack in the lash adjustment
    The main problem with most solid lifter cams are their power bands are usually high RPM, because they're designed to rev very high for racing applications. Most production solid cams have lots of overlap, so they're piss poor for pulling vacuum, and if you're running accessories or have an automatic trans, can be a problem.
    Hydraulic roller cams are much better suited for street/strip application, allow for fairly high RPM, and you don't have to worry about adjusting valves at all. Plus, they're friendly for engines running accessories, especially stuff dependant on engine vacuum.
    Hope this helps a little....
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by commy vk View Post
    Cams come in stages and I have a stage 1 as I'm on lpg
    LOL....
    The difference cant be basically spelt out as to what type of lifters they use. Hydrualic use hydraulic lifters and solid use solid.
    There are pros and cons to each camshaft. Solid are good for making more power and revs to a degree. The cons are they're noisy, u need adjustable rockere and the clearances need adjusting fairly regulary.
    Hydrualic cam's are quieter more "street" friendly as in they're usually easier to cope with everyday. your clearances are compensated for by your the oil flowing into your lifter that the valvetrain is maintenance Free compared to a solid setup. Theres Potential to make decent power on these.
    As for your other part of the question yes you can get both types for a 202
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VH SL 202
    Feb 2010
    Quote Originally Posted by Pub247 View Post
    LOL....
    kool thanks just another qustion what type of cams are the standard 202's running solid or hydralic
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by TY318 View Post
    Hydraulic.
    Honestly mate, for a street engine, stay with hydraulic. For a strong street/race engine then go solid for sure.
    VH SL 202
    Feb 2010
    dose anyone know of a place in melbourne that dose cams for the 202's and what would be an avrage price
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Crow cams or wade cams are both in melbourne and sell cams to suit price would be anywhere between 100-$300 id say depending on cam specs and material
  1. vr irs to solid diff
    By VRskidRIG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 07:34 PM
  2. lsd solid diff with abs
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2009, 09:01 PM
  3. Replies: 9
    Last Post: 11-05-2008, 04:13 PM
  4. whats involved in getting cams licence?
    By calais_304 in forum Motorsport
    Last Post: 31-07-2006, 11:00 AM
  5. Whats involved replacing IRS with a solid diff...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2006, 02:43 PM
