Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: 202 noisy rocker/lifter/POS
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Default 202 noisy rocker/lifter/POS
    Iv have read many threads on this topic. To give you an idea of what i did was remove the old head, put on a cleaner, valve lapped, slightly ported head.
    Since doing that i have gained many good things but one bad one. A noisy tapping noise that increases with revs.
    Common fixes iv read:
    Bad oil pressure (I have a small leak on the bottom end somewhere, never caused a problem tho)
    Loose broken rocker/pivot arms (All cleaned and tight to torque specs)
    Bent push rods (All straight)
    Lifters (Dont see why they would be playing up on this head and not the other).
    After doing the head i gave it an oil change too, so new oil and filter.
    I have a new set of lifters here, but i was saving them for the new 202 im building. I dont know what else could be causing this annoying ticking noise. I think the timing might be slightly out too. Going to read up on how to use a timing light tomorrow in hope to getting better timing.
    Also forgot to mention the last head had a floged out spark plug thread in number 5, to it ran like a bag of shit, but no tapping noise like this new head has.
    Also i used the rockers and pivot arms that were with the new head, not the old ones.
    Old head:
    New head:
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Its not the valves clicking is it?
    When they hit the seat?
    Are the valve springs standard?
    Not worn to the buggery?
    You don't have a sticky lifter?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    I don't know why... But I had a shitty 3.3 blue motor in a VC & if I changed the oil & didn't fit a RYCO oil filter the lifters would rattle on start up.
    As soon as I changed the filter to a RYCO brand the noise would stop...Not sure if this info can be any help but for $10 worth a try.
    VS
    Jul 2010
    Cheers for the ideas guys. What ill do is rip the cover off, double check. Chuck in the new lifters i guess too. Its really annoying.
    ari666's Avatar
    1966 impala
    Mar 2009
    "chuck in new lifters" sounds a lot easier than what it is. make sure you bed those babies in or you will have a lot more noise this time round.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Heres for working on the timing, timing light@Everything2.com , seems pretty straight forward. Have you tested the light yet, see if it works?
    Ronald Reagan (1986)
    VS
    Jul 2010
    Cheers guys, yea mate the timing light works. Ill read up soon. I better read on how to bed the lifters before i crank it over, once i figure out why its not cranking now lol.
    I also removed the dizzy to find the plastic cog was missing teeth, so it has a metal one on there now from an oil pump. Only problem is, i didnt take notice of which way to rotor button was facing so i think im going to be up shit creek because its not going to be firing right. I dont know to much about timing and dizzys.
    Nov 2008
    Smithton, Tasmania.
    There's a little notch on the dizzy that is where it fires for TDC on #1 cyl, turn the motor over untill #1 piston is at TDC and check where the rotor button is in relation to the notch. Adjust acordingly.
    Love the old bangers. So easy.
    VS
    Jul 2010
    Cheers for that, but how do i know when #1 is a TDC? Wouldnt the head be required to be off to see that? Or maybe just remove #1 spark plud, put a screw driver in it and wait till its at it highest point?
    Nov 2008
    Smithton, Tasmania.
    VS
    Jul 2010
    Cheers mate, will do that now. Dont supose you know how to bed lifters too, did a good search and all i found was you should bed them, not how to.
    Nov 2008
    Smithton, Tasmania.
    I've only ever done it by just runing the through the rev range nice and gently. Slowly up, hold at around 1500rpm for a couple seconds and then slowly down.
    I've only ever done it with solid lifters though.
    VS
    Jul 2010
    Ah true, these are hydraulics. I suppose i can give that way ago. I cant really be without a car for too long. Not to mention if this doesnt work, i dont know whati could get for $2 to fix it.. Bloody floods.
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    plenty of moly bond on each cam lobe and the base of each lifter. really should use a zinc additive to the oil to do it. once its all molybonded up try and do your best to have it all ready to fire immediatly so your not cranking-cranking-cranking, trying to get it to fire. once its started then itll take 20 mins of 1500rpm up to 3000 rpm then back down again.
    its pretty easy, just a pain in the arse.
  16. #16
    VS
    Jul 2010
    Ah true, its there any other way, dont have any of that lube nor can i oford it at the moment. Im pretty sure these are V8 lifters too, just did a search on the part number.
  17. #17
    VS
    Jul 2010
    I think i burnt my coil out some how. I have no spark anymore. Tested by removing lead one, put another spark plug on and earthed it to one of the strut bolts and turned the key, no spark.
  18. #18
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by ari666 View Post
    What!? Lifters on the Holden 6 are cruisy as to do!
    None of this manifold removing like the V type engines
    And when using he screw driver method you can get TDC almost perfectly if you really can be bothered. You mark on the balancer and block when the pistons stops moving up and then wind it further till it just starts to go down again and mark it on the balancer again. Put another line between your two balancer lines so its as close to the middle as possible and then align the middle line with the line you drew on the block.
    You dont need to do that, screwdriver method is plenty accurate enough for these engines.
  19. #19
    VS
    Jul 2010
    Easy if you have the tool. Like 10mins of wanking action with a screw driver to get one lifter out. Was not easy.
  20. #20
    VS
    Jul 2010
    Coil has been replaced and got it to run, but still tapping like crazy, tho i did find the inspection plate leaking, badly. So waiting for the gasket to dry out and hope once it doesnt leak there it wont tap. I think its taping worse tho.
    Could i get away with using thicker oil? Which would you recommend that i use? Its pissing me right off.
  21. #21
    Nov 2008
    Smithton, Tasmania.
  22. #22
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    what did you try this time to fix it did you fit lifters and run them in for 20 mins at 2000 rpm
  23. #23
    VS
    Jul 2010
    Did run it for 20 mins going from 1500 to 3000. But currently the inspection plate is of cause the bottom of the gasket got pushed up. Just waiting for it to dry then do it again. The lifters i got were a Nason: RHT969
  24. #24
    VS
    Jul 2010
    Not the best vid but the only recording device i have.
    Edit, got hold of a better recording device.
  25. #25
    VS
    Jul 2010
  1. lifter stuff
    By ari666 in forum V8 Development and Modification
    Last Post: 11-08-2010, 03:43 PM
  2. VN V8 - Rocker/Lifter/Pushrod Noise.
    By 8rody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2010, 03:29 PM
  3. noisy lifter replacement
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2009, 10:59 AM
  4. Noisy Lifter (one or more)
    By bigdaddycool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-06-2009, 09:58 PM
  5. lifter suicide?
    By FadeToBlack in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 05:33 AM
