Results 1 to 14 of 14
Thread: Transmission Selection Help.
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Default Transmission Selection Help.
    Gurus,
    Down the track (after I win lotto at this rate) I'll be replacing the engine and transmission in my faithful VH SL. At the moment shes mostly standard with 202, trimatic. I've already swapped the diff for a 10 Bolt and installed a tail shaft to suit. I have a HDT 304 out of a VK (B Cast heads, Flat tops, 955 manifold, quaddie, may be cammed and rolled rockers to) which is going in and, up until recently, I was thinking about a TH700, 4l60 from a VN mainly because I don't want any wiring complications or harnesses to deal with. Really the only reason for this selection is because it was suggested to me by a friend and I know little to nothing at all about a good choice so I kind of ran with it.
    My only criteria for a transmission is that I would like 4 speeds, minimal electronics and minimal heartaches for installation. I would also like to fit a shifter to it (B&M, Hurst) purely for looks. Not much more. I've wanted one for years and this might be the only chance to fit one. Everything else is optional. I occasionally go on long drives so I want something that will cruise well on the highway with reasonable economy.
    What I would like is other peoples opinions for any more suitable candidates if any. If you think that the standard trimatic will suffice but with a gear ratio change, discuss. What about stall converters? Will stock ones do? This combo will be in my daily driver but would like to stretch the legs every now and then. No drags or track days though. Just like being pushed back in my seat and scaring the missus.
    The block is a trimatic pattern (obviously) so I'm aware that an adapter may be required depending on the box. Please let me know what you think or if more information is needed. I've always got my ear to the ground about parts I'm after for this car so the sooner I know exactly what I'm looking for the better.
    Thanks all.
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    Gday, t700 has a electronic speedo. (i think). why not go for t350-t400?
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    not to mention the fact that turbo trans will not fit an aussie pattern... i think your block will decide for you. im pretty sure theat all VK 308's had aussie/trimatic pattern.
    stock trimatics are great boxes, much lighter than turbo 400's. good for up around 300HP and rebuilt for about 400. stall converter depends on your cam. no need to change ratios in the box, just get a diff to suit the cam.
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    What would be the benefits of a t350-t400 over TH700?
    ari666's Avatar
    1966 impala
    Mar 2009
    there would be none.
    350 and 400 are both overkill for your build, 700 will be a royal pain in the arse to get set up. all of which are too heavy.
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    So trimatic sounds like the least amount of heartache. Is there a difference from the 6 cyl to 8cyl ones? When someone says ä shift kit has been installed"what havey they actually had done to the operation of the box?
    vkwalks39's Avatar
    Sep 2007
    Stawell Vic
    trimatic v8 are alright. 6 cyl trimatic won't fit on to v8 block.
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    VS Calais & vh sl
    Dec 2006
    deception bay
    Had a t700 in my vb once setup right it was so nice to drive especially sitting at 1750rpm at 100kph. speedo is a piece of piss just unscrew the transducer off the box and buy a speedo cable to suit th400 in early commo readily available due to the fact vb/c had them. I have a diagrams on how to setup the throttle valve cable (kickdown) follow that and she will be sweet. some people will tell you you need to wire up something to activate the convertor lockup but every transhop i spoke to said its not a problem if you run a decent aftermarket cooler it will not effect the box at all and i never did.
    physically you will need to use a custom trans crossmember and also notch the small chasis rail about 10mm from the crossmember forward un till it tapers out as the pan will hit not hard to do just need a grinder and a mig.
    Attached Thumbnails Attached Thumbnails Transmission Selection Help.-img011.jpg   Transmission Selection Help.-img012.jpg
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Sweet thanks. Is the TH700 that different to the T700? I'm lead to believe one is electronic and the other isn't. Forgive my ignorance I just don't know any better.
    ari666's Avatar
    1966 impala
    Mar 2009
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Even with an adapter I mentioned in the FIRST POST Ari?
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    Quote Originally Posted by ari666 View Post
    th350 fit my v8 blocks?
    they came out in some hqs....
    HJ premier
    Jun 2010
    ari is saynig that if your block is an aussie pattern a T700 will not fit because its the wrong bolt pattern
    some of the older holden blocks are turbo pattern, you CAN get them machined to suit certain patterns if you think its worth it.
    ari666's Avatar
    1966 impala
    Mar 2009
    AP014
    365 bucks. its not just the bracket, the spigot hole in the crank is deeper for a turbo trans, so it if yours is a trimatic, it needs to be drilled out, spaced somehow, whatever. if you wanna go through all of the expense and effort for the sake on of running a heavy and pointless trans, then by all means. go for it.
    and jonno, your block was a turbo block. op was saying his is a VK 304 which is a trimatic block.
    anyway nevermind. i have put in my 2c
  1. 304 Cam selection
    By VTClubby98 in forum V8 Development and Modification
    Last Post: 26-11-2010, 03:30 PM
  2. 304 cam selection & where to buy
    By jimmyd17 in forum V8 Development and Modification
    Last Post: 11-01-2010, 04:56 PM
  3. amp selection
    By clyde in forum Car Audio
    Last Post: 07-11-2007, 06:29 PM
  4. Need help with Transmission Selection
    By darkmoon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-12-2006, 08:48 PM
  5. Cam selection
    By hotvrv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 04:29 AM
