Meant to post this up a while ago.
If you are having trouble with your VK electric windows particularly the rear, it quite often the carbon brushes have corroded up so that the spring behind them is unable to push the brushes back onto the motor.
So you can pull them apart and lube them up as well as working them back and forth.
Try giving the motor a bit of tap to loosen them up also may save pulling them apart.
Cheers,
Tim
