Results 1 to 2 of 2
Thread: TCI Shifter into VK
    VK wagon
    Dec 2010
    Hobart
    Default TCI Shifter into VK
    Hello All,
    Basic Question but its annoying me a little
    Put a TCI shifter into the VK and now cant get it started. I assume its some thing to do with the nuetral cut out switch.
    There are 2 larger guage purple wires and two smaller guage wires (pink and green) that run into the shifter.
    I assume the larger guage wires are the nuetral shut off and the pink and green are the reverse lighhts?
    Am I wrong or is there something else I'm missing. Motor just doesn't turn over whe I hit the key.
    Car is a conversion from carby 6 to carby 8 with a t400. I've chopped the wiring out of the engine bay loom that wasn't needed but the EST box is still in there. Would this be causing the issue?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    yep. put a loop of wire in the purple wires and it should fire.
    edit* and then fix the switch
  1. Just put a B&M shifter in my vp
    By scouser king in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2011, 07:00 PM
  2. B&m shifter
    By swamprat97 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-06-2010, 12:36 AM
  3. b&m shifter in the vl
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2007, 06:02 PM
  4. vy shifter to vr
    By crg07 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2006, 09:23 AM
  5. B&M Shifter
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2005, 02:43 PM
