Results 1 to 10 of 10
Thread: Going to put a ecotec into a VK, is there anything i need to know?
    1988 VN Executive S1 and 1984 VK Executive
    Sep 2008
    South Australia
    Default Going to put a ecotec into a VK, is there anything i need to know?
    I guess the title says it all so I’ll get to the point, I’ve got a donor vs and i want to know what will fit on an efi VK. I've done a bit of poking around and found out that pretty much everything from the front of the vs will bolt up to the vk with no problems but after that I’ve got no idea what I’ll need to do after that. I'm also wondering if i can still use any of the original VK exhaust or will i need to make a custom one?
    Any advice would be greatly appreciated.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    have you had a look at this thread: V6 Conversion For Vb To Vk
    its a sticky thread at the top of the vb-vk section, should have all the info you need.
    good luck with the swap, an ecotec into an early commodore should be good fun due to the lighter shell!
    Sep 2008
    South Australia
    Thanks for that mate, guess i should have looked around a little before posting.
    The only thing it didn't explain unfortunately is if any of the stock vk efi system would still be useable.
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Mate With the stock VK EFI you can reuse your fuel tank, maybe fuel pump and fuel flow and return lines. The rest is replaced with your ecotec efi system. Are you going to run a BCM or just gets the VATS turned of at the ECU? What instrumentation are you going to use?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah mate prolly the best the fuel tank and fuel lines makes it much easier than converting from carbie
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Mar 2010
    Quote Originally Posted by '88 VN Custom View Post
    no worries, wasnt sure if you had seen it or not. as others have said i would imagine you can reuse your VK fuel tank, fuel pump etc. the fuel lines may have to be altered to suit the ecotec though. couldnt imagine it being particularly hard to alter the fuel lines though
    VC
    Oct 2008
    Fuel lines should be fine. I fitted a V6 into a VC and used the original fuel lines and ran an extra line for the return. I used a VL tank. Should be able to re-use the back half of your exhaust. I used a set of headers with a custom made Y pipe which then mated up to a Redback 2 1/2" system. A standard Y pipe may work but all I had were the headers.
    Sep 2008
    South Australia
    Quote Originally Posted by VBRED View Post
    The idea is to just turn the vats off, but I’ve seen bcm simulators available from V6 conversions so i may just grab one of them if that turns out to be the easier solution, as for the instrumentation I’ve grown to like the stock gauges so I’m hoping to be able to still use the factory cluster (although I’m not sure how the economy gauge will work...)
    Also does anyone know anything about this company and their wares?
    www.caenterprises.com.au - E.F.I. wiring kits for VB-VL.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    the economy gauge is the easiest to get to work! just plug it onto the throttle body in the same spot you plug your dash vacuum line. the speedo will be difficult if you use the VS box as its fully electronic with no cables or places you can attach a cable, the rest of the gauges are straight forward. YOu should be able to use a VK EFI pump with an ecotec, im using one for my Buick V6 and have no problems, i doubt the Ecotec will require more fuel flow from the pump.
    VS Calais & vh sl
    Dec 2006
    deception bay
    yes i got my dash conversion from them and all i can say is DONT! go aftermarket gauges if you can.
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  3. Pre-Ecotec with Ecotec Performance Upgrades
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2009, 10:06 AM
  4. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  5. WTB: RECO VS ECOTEC or ECOTEC STROKER
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2008, 12:15 AM
