Results 1 to 3 of 3
Thread: vk commodore diff options
    vk commodore
    Jan 2009
    Stokes Valley, Wellington, New Zealand
    Default vk commodore diff options
    hey there looking to upgrade my diff in my commodore.
    its curently running the factory 6 cylinder open wheel diff yet it has got a mildly worked 308 & trimatic
    what is my best option as a straight bolt in diff and what sort of ratio should i be using
    Cheers Kurt
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    What cam are you using? what is its power band? What size wheels & tires have you got, what sort of driving do you do? are you going to keep the traumatic gearbox?
    I picked a VL turbo diff (3.45) for my VK based on my wheels & tires T5 5 speed its a great setup for trips & track days, down the freeway it revs lower than the 3.08 diff & 4 speed it replaced and has a quicker pickup with the higher first gear. I ended up installing a Kazz LSD centre in my Diff. You may opt for a VL V8 LSD with a 3.08 ratio same LSD as the VL turbo just taller ratio. That was you keep the same ratio as your open wheeler.
    Else you may find a 10 bolt salisbury suitable or even a detroit trutrac or Kazz LSD
    Depending on what model VK 84 or 85 will depend on iff you have a borgwarner or salisbury diff.
    Scott
    Project VK
    May 2011
    Port Lincoln, SA
    Hey guys im looking at getting a worked 202 with a ozzy 4 speed for my VK soon and i have found a VL Turbo LSD diff to put in it. . my vk is a 1985 model so will the VL diff be a bolt off bolt in job? . . please help!
LinkBacks (?)
  1. Possible Diff Options?
    By speed_freak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2009, 03:59 AM
  2. Replacement diff options
    By MichaelG in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-06-2009, 09:04 PM
  3. VB-VC Diff upgrade options help.
    By Flange in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2009, 11:54 PM
  4. Noisy Diff - VR - what options ?
    By ut1200 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2005, 10:10 AM
  5. help with diff options
    By walesy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-06-2005, 07:44 PM
