Results 1 to 3 of 3
Thread: vh diff
    VH SL 202
    Feb 2010
    Default vh diff
    dose anyone know if the vh diff with the auto they came out with is any different from the manual one
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    nope, just the ratio maybe a little diff.
    VH SS
    May 2009
    Toowoomba, Qld
    there are basically 2 diffs fitted to the VH
    the small and large (10 bolt) Salisbury
    6 cylinders & most 4.2L (excluding SS) were fitted with the same smaller salisbury. The V8 had a larger uni-joint flange fitted though and of course there both disc & drum brake setups depending on model.
    5L were fitted with the larger 10 bolt Salisbury. The autos eg SL/E were often fitted with tall gears eg 2.6:1 whereas the manuals were fitted with 3.08 gears
  1. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  2. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
