Results 1 to 13 of 13
Thread: Vh from starfire 4cyl to 304ci V8 questions.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Question Vh from starfire 4cyl to 304ci V8 questions.
    Hey guys, probably been asked a million times. But I currently own a VN commodore with a factory 304ci and T5 gearbox. Recently it was involved in a accident and the rear was hit. Running gear was completely fine though. So have removed the motor, gearbox and drive shaft.
    Im now looking at an original mint VH commodore with the 4cyl starfire motor and auto trans and planing on doing the 304ci convertion. I am doing all the work myself and really want to know whats involved in this? what do i need? what will i need to custom make and modify? What will need swaping over? also are all the mounts the same? Is it all bolt in?
    Thanks heaps in advance. Just what to know how easy it is just to get this vh instead of paying 3x the price for a factory V8 one.
    Cheers Mike
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Use the VN engine K frame. You need to do all the brakes, suspension and diff. The 4 cyl used smaller items.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    With T5, i'm not so sure. Should bolt in.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    look at my site then ask further questions
    VH SS
    May 2009
    Toowoomba, Qld
    easiest way is drop the engine, k-frame, steering rack, struts, control arms & brakes from the VN in one assembly
    and then wheel it over to the VH and bolt it straight up. That's the front end sorted.
    you then need to find yourself a disc brake rear end for the VH (VN diff is wider than VH)
    T5 will need a special rear mount, available from Dellow or Castlemaine Rod shop
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Ahh, I see. I should have it by the end of the week. Just wondering is any modifications needed to the drive shaft? And what diffs can I use? eg. VH, VK, VL?? Cheers Mike
    LX SL/R torana, HZ SANDMAN, VH SL/E top 30
    Apr 2009
    BALLARAT
    You have to make a custom gearbox mount, or as others have said get one from dellows or the rod shop. I cut out the mount section from the VN T5 and had a mate weld it to a new piece he built around it while the gearbox was jacked into place. You will need a VH V8 diff and the rear section of the VH tailshaft. You then use the front section of the VN tailshaft and these join together perfectly. you will no doubt need to get these balanced first.
    You also need the intermediate shaft from a vl steering rack to join the steering rack with your column and you need to source a different fuel tank. Best bet is one out of VS sedan. It has a nice internal fuel pump and bolts straight in.
    This is a great conversion but beware the costs stack up. It can get very expensive with all the little extra bits an pieces, but well worth it..
    Keep the VN close by until the job is done. It will prove handy.
    Have a read of this link for lots of great information about it by some very knowledgable guys.
    FastLane - VH EFI conversion..
    VC
    Oct 2008
    I would use a VL V8 diff or if you want a higher ratio diff a VL turbo unit. You can also use a VL rack, not sure about the VN rack, maybe wider? You can also use the VL fuel tank. If you use the VL diff you mate the back end of the VL tailshaft to front half of the VN tailshaft same as the VH mentioned above. At least the VL rear axles are Borg Warner.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Apr 2009
    BALLARAT
    Your VN rack will work. I used one in my VH.
    You will just need to get the intermediate shaft from a VL to marry up your steering column and the VN rack as the VN rack has a smaller steering knuckle setup. (Or whatever its called....)
    Sorry by VN steering rack do you mean the K frame? The K frame will fit. You use the original VH steering column, and you use the VL part to join them together.
    VH 304 EFI T5
    May 2009
    Welly, NZ
    Oh sweet, I get it now. Suposed to be getting the VH this weekend. Fingers crossed.
    Thanks Mike
    VH SS
    May 2009
    Toowoomba, Qld
    I've got a VN rack and k-frame in my VH
  1. VN-VT V8 5L 304ci Heads
    By 8rody in forum V8 Development and Modification
    Last Post: 10-12-2009, 05:26 PM
  2. vc 4cly starfire questions
    By muffman001 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-03-2009, 09:30 PM
  3. rb30et or 304ci
    By VH commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-09-2007, 12:16 AM
  4. 4cyl VC - questions
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-11-2006, 04:10 PM
  5. 304ci vk seems lazy
    By azza009 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-03-2006, 08:37 AM
