Results 1 to 7 of 7
Thread: Interrior up down locks > slide locks
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Default Interrior up down locks > slide locks
    My old pov VB has the usual push down pull up interrior locks. I want to change them to the slide locks. Has any one done this and what is involved. Is it as simple as removing the slide lock components say from a later VK or VL and fitting them up to my VB?. I am sure that the VB SL/E was fitted with the slide locks.
    ve sv6
    Aug 2010
    yes the vb sl/e did have slide locks, you need all the slides and the rods for the front and slides, the slides, rods and there is also a plastic L shape piviot for the rear door that can brake easy when removing. you best bet is to find a car and pull them off your self so you know what you need and how it goes together, but is pretty easy.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I changed my VK wagz from up/down locks to slide locks. Like wat Glenn said, it's easy, just gotta change the bits over. Rekon I paid $20 from a wrecker for it all.
    I didn't think VB's had slide locks tho so wouldn't think they'd have the cut-outs for the bits to sit in. Not 100% sure tho.
    VH SL/E 5.0
    Nov 2009
    Yeah glenn is right the VB SL/E had the slide locks with the central lock option.
    commodore
    Aug 2009
    australia
    you will also need the doortrims with the cutouts for slidelocks or to cut yours out to suit, but then you will be left with the holes in the top where your old knobs were if you cut yours out.
    Jul 2009
    Melbourne - SE
    I have new door trims with the cut outs that is why I asked the question.
    Jul 2009
    Melbourne - SE
    I ended up getting slide locks from the wreckers out of a vl. Back doors were easy the front ones were a little fiddly. I use some whizz snips to cut the door metal on the donor cars to get the white slides that fit the door. They are so brittle. So my new door trims are in.
  1. locks?
    By Rayz 1992 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-10-2010, 03:04 AM
  2. VT door locks
    By stevevt18 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2009, 06:36 PM
  3. wtb: vk or vl slide door locks
    By NOT.BT1 in forum Swap / Wanted to Buy / Trade
    Last Post: 12-04-2007, 12:56 AM
  4. locks
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 09:11 PM
  5. Locks!
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2006, 09:49 AM
