Hi, does anyone have any avice on what actually needs to done to convert the trimatic auto speedo setup so I can use the autometer speedo in kilometres that has the electronic odo readout? Not sure where to start with this!
How about starting by making one thread not 2!
Well I was not sure on which section it should have been under after I posted the first one!
i think you need to hook up an electronic speed sensor on your tailshaft
you may be able to use / modify a VN-VT electronic speedo drive to suit, you would need to use the trimatic gear on the end, also depending on the pulse rate either use an adapter or change gears to get the pulses correct
scott
