Results 1 to 3 of 3
Thread: Torque settings on VK 6 suspension
    toxic VL is offline Project VK begins
    85 VK
    Dec 2007
    MARY'HOLE QLD
    Default Torque settings on VK 6 suspension
    Hi all,
    Just wanting to know what the torque setting should be on the;
    lower ball joint
    pivot bolt
    tie rod end
    wheel hub nut
    Any help would be appreciated.
    My other lover is my VK
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    lower ball joint 80-95
    pivot bolt (to x-member) 95-110
    tie rod end 72-90
    wheel hub nut. finger tight, then rotate back and forth. then tighten to 20nm, loosen the nut 2 turns then retighten to 12nm.
    no idea where your gonna find a torque wrench that goes as low as 12nm though. mine starts at 35nm i just go by feel. last time i did it i fitted the wheel and guessed how tight it was when the wheel stopped moving in and out. if that makes sense.
    85 VK
    Dec 2007
    MARY'HOLE QLD
    Thats awesome thanks heaps, my torque wrench is the same but get what you mean, i'll head straight out and do them now
    Cheers again
  1. torque settings suspension
    By MYVESSV8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2010, 02:07 PM
  2. 304 Torque settings please
    By deanos70 in forum V8 Development and Modification
    Last Post: 05-09-2009, 06:57 PM
  3. torque settings
    By zedproject in forum General Discussion
    Last Post: 28-11-2008, 05:12 PM
  4. torque settings?
    By vk202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-05-2007, 07:34 PM
  5. torque settings
    By atreyu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2005, 01:15 PM
