Results 1 to 3 of 3
Thread: Need help, Wiring problem in VH sl, no more accessory power!
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Exclamation Need help, Wiring problem in VH sl, no more accessory power!
    hey guys, last saturday my commo broke down in Yarra junction for some reson i was just about to take off and bang car stalled, i was looking around for about 10 mins and i had no accessory power so all i did was just hard wire the fuel solenoid to the battery to get me home, but i had no idicators or radio and no thermo fans witch cause the motor to get hot but at a safe temp to drive home.. theres no accessory feed.
    all the fuses are fine i have checked fuses in the engine bay and in the car and A ok.
    where does the accessory power come from??? and if you know what else could be the problem
    also another quick question when i break my parkers come on
    thanks fellas!
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    there is a BIG inline fuse just near the battery. its not really a fuse, more of a loop of wire. find it by following the fat red wire from the battery to the starter/fusebox/interior and get rid of it.
    budgieVH's Avatar
    May 2009
    Australia
    okay i checked out the ignition switch, the brown wire is all burnt and stuff, but when i wiggle the plug around while ignition on i loose accessory feed.. so i will replace that, the barrel its self is a bit dodgy too,
    thanks for the help dude!!!!!!
    Budgies Car Sound
  1. Accessory wires!
    By seventhspine in forum Electrical Wiring / Questions
    Last Post: 17-12-2010, 09:49 AM
  2. Changing head unit accessory power slightly
    By JOZ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-06-2010, 05:48 PM
  3. VE 12 V Accessory Power Power Outlets
    By ansett727rma in forum Electrical Wiring / Questions
    Last Post: 24-08-2008, 07:43 PM
  4. Accessory Power Outlet Fuse?
    By adisinha in forum Electrical Wiring / Questions
    Last Post: 04-10-2007, 02:21 PM
  5. VZ accessory wiring
    By Dover1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2006, 04:21 PM
