Results 1 to 22 of 22
Like Tree2Likes
  • 1 Post By ari666
  • 1 Post By vh-holden
Thread: VK removing brake booster?
    1985 Vk Commodore SL
    Feb 2011
    Bundaberg
    Default VK removing brake booster?
    Hi.
    A fe days ago my brake booster finally packed it in and i need a new one, but everyone i've talked to says that the brake booster is extremely hard to remove, I don;t really know how to remove it and all I've found are instructions on how to remove the brake boosters from 100's of otehr cars.
    anyone got a tutorial for a VK?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    not a tutorial, but its pretty easy.
    1. undo the master cylinder support bracket and master cyl nuts to booster, bend it out of the way but dont kink your hoses
    2. unside the car you need a ratchet spanner or tube socket. from memory they are 13mm i think there are two, but may be 4
    3. the hard part is undoing the clip from the brake pedal to the booster. make sure you dont lose the washer when you pop the clip off. push out the pin.
    4. remove the booster.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Yeah I'd say the hardest part is removing the clip and pin from where the rod goes to the pedal. Other then that it's pretty straight forward. Maybe do that bit first, then the hardest part is over!
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    I agree with Danny and Ari, the clip is the pain in the ass, the 2 nuts going thru the firewall to the pedal box are 1/2" one either side of the brake pedal.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by Staggie View Post
    ah yes. soz for the bad info. hate how the VK swaps metric to imperial
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    When is did it found the hardest part was getting the boosters pushrod off the pedal pin as the pin wouldnt come out, it was either seized in there pretty damn good or not removable. i couldnt see well enough to know which.
    VH SS
    May 2009
    Toowoomba, Qld
    Feb 2011
    Bundaberg
    Awesome, thanks for that guys.
    just went to the wrechers and i found a bunch of booster and master cylinders, and i thought, while I'm replacing the booster, might as well do a bit of an upgrade. But I got a few questions before i go through with it.
    Do I really need a brake upgrade if I still have the stock front disks and the rear drums?
    And what boosters/MC's can I fit in with no modifications needed?
    Basically there are basically all commodores from VC's to VE's sitting at the wrechers and msot of them have boosters, what ones can I put in?
    Edit: The pin doesnt worry me because I can get a pair of small bolt cutters in there to cut it off, and those pins I can get from most hardware stored.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    pin would be hardened so it doesnt snap with fatigue i would assume, but anything up to VS booster will bolt straight in, and VT/VX masters will bolt to vs boosters, but doing anything is useless while you still have drums on the rear as any newer master is proportioned to suit discs and will not have a residual pressure valve which is need for drums, leave it stock unless you give the whole setup a revamp.
    Jul 2005
    Quote Originally Posted by ari666 View Post
    I feel your pain mate, gets worse when your doing conversions when you have to deal with metric and imperial theads as well.. got well versed with the tap and die set doing mine.
    as VK 3800 said, anything up to a vs master will bolt straight up, but def get a rear disc setup or you will be waisting ur time.
    Feb 2011
    Bundaberg
    But would it still work with a VS booster and VT MC? I will eventually do a rear brake upgrade, but at the moment, I'm strapped for cash.
    -EDIT- i did notice a VK that had some old disk brakes, I think they were stock because it had the JM8 option code on it. What would I need to do to get those disk brakes to replace my drums?
    Dirbatua's Avatar
    Dirbatua is offline Say No to Chev Badges
    VX SS, VR Clubsport
    Apr 2003
    S/e Victoria
    Just look for a 1" Master from VB-VP (not sure about the VR/VS ones) is generally the best upgrade since it will work with the drums and if you later put larger brakes on the front or change to a disc diff you won't get a dead spot on the brake pedal, no point in getting a VT master since the 1" works better for the old girls compared to the VT with the quick fill and just bolts up without having to #### around with anything since you need to find one without ABS, if you look on the front right of yours it will say 15/16 which is the standard, if it just has a big 1 don't bother changing it, as for the booster just try and find a V8 one otherwise a standard one works just fine.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by Pie-VK View Post
    lol GOOD LUCK. we are not talking about a cheap split pin here. its a locking pin that doubles as a spring keeping the pin tight. replace that with out the washer or with a different pin and you are asking for trouble. no the only way to do that job is to do it properley.
    and dont mess with your brakes if you are "strapped for cash" everything soon adds up and your brakes are the most important thing on your car.
    LX SL/R torana, HZ SANDMAN, VH SL/E top 30
    Apr 2009
    BALLARAT
    AGREED!!!
    Use the factory stuff. Putting some cheap chinese made P.O.S pin between you and your brakes is a stupid idea. Do it properly or kill someone.
  15. #15
    Jul 2005
    Do you want the easy way or hard way?
    Easy way - Swap the whole diff
    Hard way - swap axles, bearings and brakes over to your housing.
    *EDIT* if your that tight on cash, just swap the booster to fix your problem and leave it at that. As ari & other have said DONT do a half assed job on your brakes or you may end up killing yourself or someone else, and being in a whole world of trouble.
  16. #16
    Feb 2011
    Bundaberg
    Thansk for your help guys.
    I did get a booster from a VL, fit straight in, and it was one of the old one's at the wreckers that wasn't rusted to bits.
    Somehow I did snap the pin, and it was actually pretty easy. I think the pin might have been worn anyway. but I got another pin, exacly the same from the same VL and it fit perfectly.
    I have yet to do a brake bleed, I think I'll do that in the morning. But i'd have to say the hardest part was either the pin before it snapped trying to wiggle off the booster fromt he brake pedal.
    also, aren't there kits for converting drums to disk instead of having to remove a whole diff? Are they any good or is it just better to replace the diff?
  17. #17
    Dirbatua's Avatar
    VX SS, VR Clubsport
    Apr 2003
    S/e Victoria
    its easier just to get a VH\VK Salisbury Disc to Disc diff or a VL Borgwarner Disc to Disc then trying to convert a Drum to a Disc.
    If you get a VL Diff though you need to use 2 different pieces of tail-shaft, Vk front and VL rear, im pretty sure but someone will correct me if i am wrong.
    You can get a disc to disc diff with the handbrake cable on it through ebay from anywhere from $50 if your lucky for a VH\VK one or around $200 for a VL 3.45 Open Diff up to $800 for a VL Turbo 3.45 LSD diff.
  18. #18
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    There ya go Ari, forget all that nonsense about original engine numbers , I agree with you on this. If you don't worry about the brakes, you won't have to worry about the rest of the car (or yourself) either...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  19. #19
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Any suggestions on how to get the pin out, other than that it is hard? I've tried slamming the door, bonnet and boot in frustration but it is still there.
    ECOTEC KICKED IN yO!!!!!!
  20. #20
    May 2004
    darwin
    I persevered. For anyone reading this who is struggling to get it out, the pin is a weird shape and that can cause some confusion. I thought it was just a normal R shaped pin, but it isn't. A picture says a thousand words so here is a picture -
    On mine, the loop was at the bottom around the edge of the washer. I levered it up with a small screwdriver, then pulled it out with long nose pliers.
  21. #21
    fullysick33 is offline fullysick
    vk calis / VZ berlina
    Jan 2010
    albury
    4 bolts up under dash and you will need to disconnect the brake pedal under the dash 2 bolts on master cylinder un do it should come out easy if it is a six if it is and 8 bit harder
  22. #22
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Mate as the other guys have said in here on how 2 remove it. Once u done it, u b like' gee, that was a piece of piss. Any1 else wana remove there's, ill do it, cause I know it easy'. That's wot u be sayin afta u do 1.
  1. Brake Booster???
    By MY_84_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2010, 08:18 AM
  2. Removing Brake Booster 97 VS
    By Gurner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2010, 11:58 AM
  3. VN, VP brake booster to VR
    By VR38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2009, 11:41 PM
  4. Removing brake booster any tips?
    By Pub247 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2008, 03:30 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
