Results 1 to 6 of 6
Thread: v8 pushrod bent
    squiblex's Avatar
    squiblex is offline UNSEEN
    VK 308
    Nov 2008
    SA great mate!!
    Default v8 pushrod bent
    hey i have a old holden 308 it has a bit of head work and a cam, it had a bit of a knock commin from the top wen i bought it i found it was one of the rockers looked loose wen i pulled the rocker cover off i took the roker set off that was loose an found that one of the pushrods was bent pretty bad!! wat would cause that?? an how do i kno if it will do it again wen i put a replacement back in??
    PUT YA FOOT DOWN YA BIG GIRL !!!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    seen it heaps quite common especially when you flog the crap out of them
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    squiblex's Avatar
    VK 308
    Nov 2008
    SA great mate!!
    ways a good solution to fix it from happenin again??? an would it done any damage to the inside of the moter???
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Probably woulndt have hurt it, its only going to rub on the head a little if its really bent other then that there not too much else it could do.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by squiblex View Post
    lol, i dunno... try not reving it till it valve bounces...
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Bent push rods are normally caused from valve bouncing. The valve springs might be a bit weak or it might be that someone has just thrashed the guts out of it.
  1. Pushrod lengths in 304 - Converted from 308
    By aidanhq in forum V8 Development and Modification
    Last Post: 26-10-2010, 11:30 PM
  2. VN V8 - Rocker/Lifter/Pushrod Noise.
    By 8rody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2010, 03:29 PM
  3. Snapped a Pushrod
    By VPCalais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-11-2006, 06:19 AM
  4. pushrod to DOHC. Is it possible?
    By SaGe in forum V6 Development And Modification
    Last Post: 30-04-2006, 12:04 AM
  5. pushrod to DOHC. Is it possible?
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2006, 08:49 PM
