Results 1 to 2 of 2
Thread: Ignition timing set up for 6cyl blue motor
    VH
    Jan 2011
    Gold Coast
    Default Ignition timing set up for 6cyl blue motor
    Is this correct: No1.cyl top dead centre with harmonic balance groove in line with cam cover timing mark on 0 degree. Distributer/ Rotor button marks in line with housing mark.
    Just fitted new distributer, wants to cough back through carbbie even when advanced and retarded distributer. Haven't touched valve timing - still as it was when car was last running.
    Thanks.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Sounds like it's 180 degrees out.
    Easiest way to do the timing, I do this on our v8's but would be the same with the 6's. Put ya finger over number 1 spark plug hole (remove spark plug), turn the motor over (even by hand will be fine) until ya feel positive pressure against ya finger, this will be the compression stroke. Now get it at top dead centre where the mark on the balancer is at 0, then turn the motor by hand until the mark on the balancer is at 6 degrees advanced (watever ur timing setting should be, my old 173 I'm sure was 6 degrees), and when it's there, plonk ur dizzy in, making sure the rotor button is smack bang on the mark you'll be using for number one, then chuck the cap on and give that a crack.
    It doesn't matter where u line the dizzy up to in these things, as long as when u do the timing, u set the rotor button up at watever point ur using for number one....if that makes sense.
    Doing it this way, ya won't even have to get the timing light onto it! When I chucked the 253 in me VK wagz, it started first blip of the key and idled spot on first shot!
  1. i have a vl 6cyl just had exchange motor put in, the cars factory auto the new motor
    By highmat_8686 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-11-2008, 09:32 AM
  2. Timing for EFI blue 202
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2007, 05:12 PM
  3. Timing & Gears. = Blue 202
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-11-2006, 09:47 PM
  4. WTB: VH Blue HEI Dizzy for 6cyl
    By electric_monk in forum Swap / Wanted to Buy / Trade
    Last Post: 02-06-2006, 03:20 PM
  5. VK 6cyl starter motor
    Last Post: 04-04-2006, 02:47 AM
