Results 1 to 20 of 20
Thread: holden lj torana fuel tank
    VH SL 202
    Feb 2010
    Default holden lj torana fuel tank
    hey guys
    dose anyone know if the fuel tank outa a lj torana would fit into a vh commodore?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Ummm why? The fuel tank is 63 litres in a Commodore. LJ isn't even near that.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    45 litres in an LJ tank
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VH SL 202
    Feb 2010
    well i wanted to change the tanks from filler it up at the back to filler it up at the rear and i didnt wanna have the trouble of cutting and welding and maybe blowing myself up lol
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well to do that, you need to get an engineer cert.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    no would be completely different, not a bolt in job. can i ask why? your still going to have the hole for the old filler anyways.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VH SL 202
    Feb 2010
    Quote Originally Posted by VK SL 3800 View Post
    atm its sitting in my dads workshop so i have the chance to do some work to it
    commodore
    Aug 2009
    australia
    if you were going to go to all that trouble just get an alloy droptank made or use a hq-wb stato tank the lj one is too small.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by TY318 View Post
    That doesnt make sense, they are both fuel tanks, they both hold fuel and the torana one is smaller. So you want to do work to it and the only thing you can think of is putting in another tank that will do the exact same job no better or worse then the current one. IDK, fix some of the things that are actually wrong with it, oil leaks, change the brake fluid or something lol.
    VH SL 202
    Feb 2010
    what i ment with the fuel tanks is changing the filler location instead of on t he right quarter have it at the back just like the lil lj torana's i thort it might of been easyer to get the lj tank but seeing how its smaller i might just mod the tank i got..
    VT Calais S1, VK Wagon EFI 5.0L
    Jul 2005
    RWC guys would have a field day with that mod.. Definatly would need to be engineered.
    Personally I wouldnt bother wasting my time, really isnt going to achieve anything. If you want to smooth it out a little put a VN fuel flap on with the remote opening.
    vr v6
    Aug 2009
    I think it would be a great idea to put the fuel filler at the back,just it would be a lot of work and i wouldnt use a lj tank.If you are going to do it maybe look at using a uc torana tank(still smaller, but not as small as the lj tank) and also look at cutting/using the back panel and number plate hinge out of a xd-xf falcon.If your welding and panel fab skills are not good ,dont bother doing it and also check with the rta first before touching it.
    ari666's Avatar
    1966 impala
    Mar 2009
    your dada gonna weld up the existing filler hole? that should be fun. mate, just do as VK SL 3800 said, fix some of the existing probs first
  15. #15
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    buy some springs off the net and lower it
    ..i have no idea if its been lowered or not though..
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
  16. #16
    VH SL 202
    Feb 2010
    Quote Originally Posted by [jonnoo] View Post
    fronts already been lowered i have to wait till its regoed to put my rear springs in
  17. #17
    VH SL 202
    Feb 2010
    Quote Originally Posted by ari666 View Post
    i am!!! i found a tiny rust hole to patch up and now im boging up little dents n bolt holes that i dont want.
  18. #18
    ari666's Avatar
    1966 impala
    Mar 2009
    well then welding up a 4 inch hole in a 1/4 panel will be a great way for you to learn. "chuck em' in at the deep end" hey?
    stick some progress pics up in your ride thread.
  19. #19
    VH SL 202
    Feb 2010
    holes already welded up just gotta stick some bog over it n sand it back
  20. #20
    VH SL 202
    Feb 2010
    and ill be sticking pics up soon
LinkBacks (?)
  1. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2011, 07:30 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. Holden: Hints of Torana
    By CSP in forum News/Updates
    Last Post: 11-02-2009, 11:04 AM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
