Results 1 to 6 of 6
Thread: How to remove doors from VC Commodore
    VC Commodore
    Mar 2011
    Default How to remove doors from VC Commodore
    I am restoring a VC and I'm having rouble removing the doors from the car. I've tried to use a punch to knock out the pins but there is not enough clearance to to knock the pins out straight, they hit the door (curve of the door). I've found there is little clearance to hold punch straight too.
    Any advice/suggestions? I'd appreciate your help - thanks.
    VZ SV6 6 speed
    Mar 2011
    new south wales
    the pins in VC doors can be a real pain -there is a special tool that is available but even with the tool it has been known
    to take an hour per pin to remove. they just simply seize in
    probably best advise is to go visit a panel beater who has been around for a while, and they'll talk you through it.
    commodore
    Aug 2009
    australia
    buy a commodore door pin remover theyre about $40 and make it fairly easy to remove the doors theyre a thin rod with threaded ends and caps that goes through the hollow door pin and a metal bar with a fork on the end just put the bar over the pin and hit with a hammer but dont forget to remove the check strap pins first.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Spray and sock the pins in either CRC/WD40/Penatrine
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by SL/ENUT View Post
    Yeah but spray it daily a week in advance b4 u try pulling them out.
    VC Commodore
    Mar 2011
    Thanks for all your advice. I've ordered a door pin remover online.
  1. CANT remove doors - how to move pins ?
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2008, 08:57 PM
  2. how do you remove window leaver on back doors?
    By JohnnyO in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2008, 09:23 PM
  3. remove pin striping of doors
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-05-2008, 06:53 PM
  4. how do u remove the black strip from the doors
    By curry in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-04-2008, 05:32 PM
  5. How Do You Remove Doors Help!
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 05:30 PM
