hey guys ive got a red motor in my vh with the red motor flywheel,ive got my heavy duty clutch of my old blue motor but they didnt line up..if i put a blue motor flywheel on and bolt it all up will my red motor m20 bellhousing fit?
I dont think the flywheel will bolt up to the red motor from memory the crank is different.
measure the diameter of the flywheels and see, if the diameter is the same it should bolt up fine, but again i think the crank is different
scott
Blue motor flywheel is bigger diameter but will bolt up to red crank. Not sure about bellhousing
