I recently changed the brakes on my vt to 4 pot callipers. This has left me with the old brakes. My vb has 4 pot callipers on the front with standard vl turbo brakes on the back. To save me the trouble of taking the rear rotors off does anyone know if the rear vt brakes will bolt on witout any modification?
Nope the mounting holes are slightly closer together, easy fix is to just re drill the rear mount holes slightly closer together but then the handbrake wont work with the VT rear rotors as the inside diameter is too large and the handbrake shoes are unable to come out far enough to hit the disc even at full adjustment, and you cant use the VB original rear rotors cause there either below the minimum thickness of the VT rotor or are to smaller diameter, or both i dont remember.
Thanks for that. The vb pulls up pretty good anyway. Was just a thought.
I have been told today that Harrop have a conversion kit. Will find out tomorrow. Will report back on my findings.
it would be good if someone made a disc to suit so people with no fabrication skills like me can put them on easier.
Didnt you redrill the backing plates holes to suit the VT calipers scott?
Yeah welded up the original holes measured up and drilled new holes, got one perfect one wrong, welded up the bad one and redrilled correctly and it was sweet. Very fiddly process I think I spent 3 days on my rear brakes, between getting brake lines made, drilling & welding, machining for the discs.
scott
Ive got the Harrop conversion kit for my 4 spot (harrops, HSV). When it comes to brakes best advice is to do it properly, although there are cheaper ways of doing things I chose to use the harrop kit as it is engineered for this application. You cannot put a price in your safety.
the VN Grp A conversion is quite straight forward, if you can find the adaptor bracket for the caliper (the caliper is just a regular VN 5L front caliper - finned type)
they use larger diameter, ventilated rear discs, which are still available from DBA. That's what I'd be using if I could find someone who makes the brackets.
Check this thread out you may find it usefull
Turbo202.com.au - Boosting Holden 6 Enthusiasts! - Forums • View topic - Salisbury diff backing plates vs BW
The fronts are even bigger, uses C4 Corvette twin pistons up the front.
Am considering getting a couple of the rear brackets made by a mate. Am in the process of convincing someone to let my borrow the bracket off their groupA. As I'm sure you can imagine not the easiest of tasks.
