Results 1 to 11 of 11
Thread: converting to calipers on vk
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    Default converting to calipers on vk
    hi guys, i have a vh sle and a vk with drums on the back, i was wondering if it would be an easy job to switch the calipers on the vh to the vk, or do i have to replace the whole diff section???
    cheers
    P.S, why cant i post in the sale section?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by clutch View Post
    cheers
    You will need a whole rear axle. You will also need a new handbrake cable, bigger booster.
    And i believe you need 30 posts to be able to post in the for sale section. But i could be wrong and it may be 50.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    Sabbath''s Avatar
    Jul 2006
    sounds like a pain in the ass...
    I did mine on my car, replaced the whole rear axle in about 3/4 of a day. Cost me $75 in total. Havent got a bigger booster on mine yet, have driven it a few times and it pulled up adequately.
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Depends what diff the VK has, if its a early one it should have the same diff as the Vh but if its later is will have the same diff as VL-VS, you could just swap your axles and rear backing plates over if its the same diff as the Vh and get a new disc brake master and booster. (master cylinder is different between drum rear and disc as drum brakes require a residual pressure valve to retain some fluid in the rear slaves to stop a long pedal where as discs do not, the disc master has a different proportioning valve as discs require more brake pressure then drums to work)
    If its a different diff like the VL-vs series (made by borgwarner) you can steal the disc backing plates off a vl-vs and replace your axle seal with disc brake ones as thats the only difference between the two. you have to replace your rear wheel bearings as well as they are pressed on after the seal.
    VS Calais & vh sl
    Dec 2006
    deception bay
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Its not hard to change your existing over to discs, i did wasnt too bad at all.
    VS Calais & vh sl
    Dec 2006
    deception bay
    its not hard to do but if the are the same diff and your obviously not using the other car it is much much easier just to swap out the diff.
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    its an 85, so it probably has the vl diff
    i dont really want to switch the whole thing over because i think the vh one is whining a bit, the one in the vk doesnt whine at all
    i think ill put it in the to hard basket
    cheers guys
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    its 20 posts and a minimum of 3 months join time
    If it isnt tuckin, it must be suckin
  1. [VIC] vt sloted brakes-vy calipers, vr frnt/back stock brakes & calipers, vy braker booster
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 23-03-2011, 02:12 PM
  2. vt brake upgade .abs calipers* ar all vt calipers abs ready
    By justbad4you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 09:56 PM
  3. [VIC] VT front calipers + discs/ vn-s rear calipers painted in 2pak red
    By wildss in forum Parts And Other Items For Sale
    Last Post: 21-05-2010, 09:30 PM
  4. [NSW] SWAP: My VZ Calipers for near new VS Calipers-fronts-Sydney
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 09-05-2009, 01:27 PM
  5. VS SS calipers
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2007, 01:00 PM
