Results 1 to 18 of 18
Thread: Vb brake upgrade please help
    VB sle holden
    Mar 2010
    Default Vb brake upgrade please help
    Hello all i have a vb sle holden i have been restoring it and now i want to upgrade my braking system i was thinking vt upgrade what would i need t do this conversion r
    commodore
    Aug 2009
    australia
    vt adaptor hubs,vt callipers,new brake hoses,vt rotors and its best to upgrade your master cylinder/booster with a 1'' or late model one.
    VH SS
    May 2009
    Toowoomba, Qld
    if you use VT brakes, you really need to use a VT master cylinder & booster (which isn't a straight swap) or the pedal is shit.;
    you are better off upgrading to the VE front brakes. They work fine with a VB-VR 1 inch master cylinder
    that way you can keep your booster and just use a 1 inch master cylinder (if your car isn't already fitted with one)
    VB sle holden
    Mar 2010
    Hello Darren so if i want i can use ve front brakes that includes lines and and callipers and i can leave my master cylinder because that is 1 inch master cylinder atm
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    you need different brake lines VB one end, and what ever at the other
    VT or VE
    that is the flexible lines to the calipers
    scott
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I use a VT master with VS booster and i have a nice feeling pedal, any extra assistance and the brakes would be abit touchy IMO.
    VB sle holden
    Mar 2010
    Hello Scott ye i was going to get ve brake lines to or vt Hello vk sl3800 so use vt brake master and vs booster did u change the calipers to regards lawrence
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    You will also need to consider what wheels you are going to run with. VT brakes you will need 16inch and VE 17inch minimum.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VH SS
    May 2009
    Toowoomba, Qld
    VT brakes should fit under 15's (standard VT's were fitted with 15 inch wheels) and VE will fit under 16's (standard VE is fitted with 16's)
    you will need a caliper adapter kit and hub to fit either VT or VE brakes, will also need the brake hoses for either.
    However the difference with VE brakes is, you don't need to change the booster & master cylinder. Whereas VT you really need to or you end up with a really bad pedal.
    VH SS
    May 2009
    Toowoomba, Qld
    However the difference with VE brakes is, you don't need to change the booster & master cylinder. Whereas VT you really need to or you end up with a long pedal.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VE upgrade doesn't fit with 16", been there, tried that. Although I was told it will, it doesn't, minimum of 17" for the VE brakes with 289mm rotors.
    I do the VE upgrade for $795 for the VB, comes with rotors, calipers, pads, brake lines, fluid and mounting hardware.
    Visit my Facebook page
    VH SS
    May 2009
    Toowoomba, Qld
    it could also depend on your wheel design. I know my VN Grp A/SV5000 330mm twin spot calipers make it under 16 inch SV5000 wheels and just fit under my 16 inch Walkinshaw wheels (had to move the wheel weights), but I know another guy who couldn't fit the same brakes under his 16's
    VB sle holden
    Mar 2010
    hello all can i have the link to that ve package ye well atm i got vt gts rims 18 inch but i am thinking of putting my sle rims back on i was talking to some people today i will have to change my hubs on the front
  15. #15
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by lawrence1830 View Post
    just google it mate
    here's one I found. Might not be the cheapest around but it's a start
    VB to VP VE BRAKE CONVERSION twin piston front RDA SLOTTED 298mm
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    This is the one that I do Press Releases scroll down until you get to the Commodore VE Spec Upgrade Kit.
  17. #17
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Shameless plug.
    VH Brake Upgrade
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
  18. #18
    VH SS
    May 2009
    Toowoomba, Qld
    after reading the linked thread above ^^, it seems JC sponsor GSL Rallysport sell the complete VE conversion kit
    I've dealt with these guys on several occasions, very professional and great service. Send Greg a PM, I'm sure he'd be happy to help
  1. [QLD] 290mm brake rotors Brake upgrade for VN/VP
    By mistergTRx in forum Parts And Other Items For Sale
    Last Post: 28-11-2010, 12:04 PM
  2. [QLD] VN-VS brake upgrade
    By harro_VR in forum Parts And Other Items For Sale
    Last Post: 13-11-2010, 03:55 PM
  3. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  4. VN V6 Brake Upgrade
    By hemi01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2009, 08:25 PM
  5. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
