Results 1 to 12 of 12
Thread: VN suspension into early Commodore
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Default VN suspension into early Commodore
    From what I've read the whole front end of a VN will bolt straight into a VB-VK, but what about the diff?
    Is this a bolt in proposition?
    What about springs and shocks, will the VN ones fit an early model?
    I haven't played around with Commodores much so I don't know.
    Cheers.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VN-vp front end is a direct swap, rear end also is a bolt in job but diff is way wider and limits what wheels you can put on without having scrubbing problems. Rear springs fit dont know about the shocks i would imagine they would.
    Hangman's Avatar
    Jan 2010
    Cheers mate. The VN running gear in my sig may be going into an early Commodore instead of my Torana...
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    I got Vn springs in my vk
    And last run of vk's changed from Sailsbury to Borg Warner..I think
    So pretty sure Borg warers from vl is direct and Vn/vp are wider I velieve
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Hangman's Avatar
    Jan 2010
    Yeah that makes sense about the VL fitting and VN being wider. Thanks mate.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    think VL's are wider too.
    only the efi 6 VK ever came out with borg warner. everything else is salisbury.
    VC
    Oct 2008
    Hangman's Avatar
    Jan 2010
    Cheers mate. Might not bother. The salisbury is better than a banjo anyway.
    But I can use the springs, correct?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by ari666 View Post
    My 85 carb has a borgwarner under the back, i think all 6's went to it circa start 85 production or "b" vk on the chassis no.
    VB SLE
    Apr 2009
    i have put a vn front end into my vb with no problem. i put a vl diff into the back and had to roll the gaurds as it was a tad wider.
    hope this helps
    Hangman's Avatar
    Jan 2010
    Sweet, only lookin at the front end at the moment. I'll use the VN LSD diff I have in something else.
    VS Calais & vh sl
    Dec 2006
    deception bay
    Quote Originally Posted by lowroozer View Post
    hope this helps
    what size and offset rims and tyres you using? as i have vt clubby/xu6 wheels 17x8 with 235/45 rubber the car is lower than superlows and still has at least 20mm per side un rolled but i had to roll them to fit 19x8 +45 offset with 245/35.
  1. Welds,Convos..etc on an early Commodore..
    By saladine1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-09-2010, 06:32 PM
  2. Replies: 1
    Last Post: 14-02-2010, 06:10 PM
  3. Which engine oil VN commodore late 89/early 90
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2009, 09:59 PM
  4. Commodore hubs on early Holdens
    By DANNY8 in forum General
    Last Post: 05-09-2008, 07:19 PM
  5. QLD... FS - early commodore parts (Vb - VK)
    By pumba in forum Parts And Other Items For Sale
    Last Post: 10-05-2007, 01:07 PM
