Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By VHRickster
Thread: hi i want to know if i can use my 5sp in my vk also wenn i put a 5ltr in it
    vz ss
    Apr 2011
    bluemountains
    Default hi i want to know if i can use my 5sp in my vk also wenn i put a 5ltr in it
    my car is currently a 3.3 6cyl carby with a 5sp. i want to know if and wen i put a 253/308 in it if i can still use the gearbox/tailshaft etc cheers jas
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    i dont think u can... but im not actually sure
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VH SL/E 5.0
    Nov 2009
    Depends on how you intend driving it. Is it a stock 5spd?
    You may need an adapter plate and different length tailshaft, but like jonoo not %100.
    vz ss
    Apr 2011
    bluemountains
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Nupe, the torque of the V8 would kill it very quick, even driving like an old man/woman.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    They dont bolt up for starters and they are renowned for there weakness and being able to be broken by a 202.
    vz ss
    Apr 2011
    bluemountains
    i know its not going to bolt up this aint my 1st project is in holdens i fiq i`d need a adapter plate or something keep the info coming guys
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Dont even consider using it, they didnt release it with the EFI 202 because that would break it in no time. Find a T5 or M21 or something. Using it will only end in tears........
    RazzaCaine is offline Long Gone Now
    Mar 2010
    even an m20/21 will have issues. mine is a bit tempremental and i drive my vb like an old man 90% of the time. reverse gear crunches every other go and 3rd crunches about 25% of the time. id suggest getting a falcon t5 or a supra 5 speed if you have the money
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yours sounds like she could do with a rebuild or try some different oil, pretty much any gearbox will crunch into reverse.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Gee my M21 still original. Sure had the odd seal replaced but not noisy or "cruntchy" yet. Thats behind a mild 5er!
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by RazzaCaine View Post
    Had an Aussie 4spd in my old VH 253 with mild work (waste of time I know!!) and it did fine for close on 300,000kms, mind you I didn't exactly thrash it, but then I didn't drive it like a grandma either..... It did have a little whine in third by the time I sold it however.
    Mar 2010
    it crunches a lot going into reverse and sometimes when you put it in 3rd it seems like youre doing it without the clutch pedal in even though its flat to the floor... probably needs new fluid. gearbox has done 250,000kms without ever having a rebuild AFAIK. still, not bad for a 32 year old gearbox. would love a 5 speed but christ the conversions are expensive
    vz ss
    Apr 2011
    bluemountains
    how about i have a fully complete rebuilt vt v6 can i use box on this surely theres an adapter plate??
  15. #15
    5lt VH
    Apr 2011
    vz ss
    Apr 2011
    bluemountains
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    The gearbox you have is weak, very weak. Only good for a 4 banger
  18. #18
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    As before the gearbox will break, its more suited to sigmas and a few other 4cyl cars it was originally released with. Holden had it beefed up enough to handle a 202 because they were strapped for cash and couldnt afford to use a newer box.
  19. #19
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    Your much better off to save a bit extra and do the falcon T5 conversion.Ive had issues with everything else.Used a celica box and it blew within a thousand kms of gentle driving.Couldnt get a decent trimatic anywhere.Falcon box is a fairly straight fiorward conversion and a very nice gearbox to use
  20. #20
    5lt VH
    Apr 2011
    Mar 2009
    Coromandel, NZ
    W50 i think, The cast box
  1. 5ltr v8
    By guys-vr in forum Tuning
    Last Post: 13-07-2010, 07:41 PM
  2. wtb: 5ltr v8 sa
    By LUMPY 8 in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 10:54 PM
  3. WTB: Vt s1 5ltr [VIC]
    By The_Monk in forum Swap / Wanted to Buy / Trade
    Last Post: 19-12-2007, 09:04 PM
  4. my vs 5ltr what do you think
    By vs blown in forum VR - VS
    Last Post: 11-09-2007, 11:34 PM
