I have a VK with 253, I thinking about the idea of converting the carby to a EFI, so Id change the heads, cam among other things ofcourse. My questionis has this been done and more importantly is it do-able and is there anything I need to do to get it working well, for example would VN efi heads fit the blue 253 motor.
Thanks
there are people (I believe) who have put EFI heads on a 253, but generally speaking, the valves are too big for the bore.
question being, is there any particular reason you want to stay with the 253 ?
for the same cost of buying a set of EFI cylinder heads, intake manifold, cam and the all the associated bits, you could pick up a complete EFI 304 and drop it straight in.
isnt a 253 in a vk ilegal?
any how didnt chubby have efi heads on a 253 at the very start of his build?
Danny on here has done it, am sure he'll find this thread soon enough.
Yeah at the moment in my VK wagz we have a 253 with VN heads. (Regency approved the 253 btw). I'm only running a carb, but the heads fit and the valves open and shut fine so they definitely clear the bores, but my motor is 30thou. Rekon I put pics of the build in my wagon thread.
Just bought another set of VN heads to go on another 253, but not sure wat bore size this one has as it hasn't been cracked open since we've had it. STD bore MIGHT be an issue, don't know as I haven't ran into it yet. Gonna run a carby on this one too, along with some boost!![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
