Results 1 to 20 of 20
Thread: converting air con to new gas stuff
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Default converting air con to new gas stuff
    as title says, how do i do it, what do i need to replace, can i use parts of a newer car etc etc.. ?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Only professional air con people can do that. You need a license to use the stuff.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    yeh but i thought i could source the parts my self to cut the cost a little??
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    You can but the o-rings but you need the AC oil to lubricate them before you put them in, the new style o ring is green (R134a) old style is black? (R12), you can buy assortment packs pretty cheap, about 20 bucks i think the one i bought was and you don't need a licence, i think VK's have three different sizes, two different big ones on the compressor and about 6 little ones the same on all other connections.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    different to what i heard, the gas in the air con. Only trained and licensed people can do it.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    er ok bahaha
    how much do u recon itll cost from a guy for him to do it all
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    An absolute S**TLOAD! the cost of AC stuff is bs IMO, i got all my hoses remade a new dryer ect for the V6 and it was over $500, and thats at cheap mates rates. And i didnt get it gassed by them. If your hoses are fine just replace the O-rings and receiver dryer (necessary to replace dryer, think of it like a descant bag to absorb moisture in the system). They are cheap ($15 bucks my one was.) And gassing it should be about $150 give or take, makes sure they put in the oil as a lot of lazy blokes wont and you can blow the compressor a couple of months later or sooner. go see an Aircon place like Natrad ect.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Quote Originally Posted by SL/ENUT View Post
    And what I heard, is the gas inside it is toxic, u think I'm just gonna release it in my back yard?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    No your not going to release it, its illegal, there was no gas in the system.........
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    What are you talking about?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Call a mobile aircon guy, he will come out suck the old gas out usually free as they reuse it. (unofficially of course)
    Next pull your car appart ready for the new bits, look at fitting a newer model condenser so it will get cold enough, new receiver dryer & new TX valve which is a prick to fit 1/2 the dash has to come out on the passengers side.
    Once pulled appart get the aircon guy to fit the new O rings, TX valve, condenser & receiver dryer then gass it up you will need the car to be able to run while it is gassed up and the aircon controls to work, he will set the temp on the thermostat at the same time.
    If he fits the parts and it leaks its his fault, dont undo the pipes until he is ready to do it that way no moisture can get in which can also bugger up the pump.
    cheers
    Scott
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Cheers exactly the info I was looking for, what model commodore/any other car condenser would u reccomend? Thanks Mate
    VH SS
    May 2009
    Toowoomba, Qld
    early Commodores just used a universal fit condensor, so you just need to go to an A/C workshop and buy the modern equivalent.. The outlets are all in the same spots
    I fit one to mine, it's got a finer core than the old style ie more surface area. Fairly much a straight fit, just swap the brackets over.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Im using the original condensor and im getting nice and cold A/C, do the new ones remove the heat more efficiently?
  15. #15
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    yes, basically the new gas isnt as efficient & requires different pressures to make it work. I cant remember the exact figures but both the high & low pressure side run at different pressure, hence the change of all the gear to make it work properly.
    My VK used to run at 0.6deg C at the vent and could get ice forming on the outside of the windscreen on demist. Since fitting the 5L I have had a few issues to work through and will be fitting a much bigger condenser to solve my problem.
    scott
  16. #16
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    ok , im not using R134A so thats why i dont need a newer condenser and still get nice and cold A/C. With the 202 i had cooling problems with R134A and the condenser would burn your hand to touch but now its only hot on one side and cooler on the other.
  17. #17
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by VK SL 3800 View Post
    yeah they work more efficiently as the core has significantly more surface area than the old design
    as mentioned R134a is not as efficient in cooling as the old R12 gas, so if you do eventually retrofit to 134a (R12 is no longer commonly available) then you'll probably need to upgrade the condensor
  18. #18
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Darren_L View Post
    Just to add to this under "normal" conditions there may not be much difference but where it will make a bit difference if on 35+degC days esp hot dry weather it will cool much more, and thats my problem on my VK under "normal" conditions it works quite well but the really hot days when i need it most it only drops by a few degrees, my system is more funky than others as Im running a compressor out of a VN which was designed for the newer gas anyway.
    scott
  19. #19
    VH SS
    May 2009
    Toowoomba, Qld
    yeah I've got a VR compressor, so hoping it improves things.
    Early model Commodore A/C wasn't the greatest to begin with, hence I've tried to fit as much as I can to improve it, especially considering R134a isn't as efficient as R12
    I'm also going to fit a heater tap to mine (believe it or not VH's didn't have a heater tap fitted!!)
  20. #20
    Gse
    Gse is offline
    Opel Monza
    Jan 2006
    YouTube - Cold Airco
    Blown out temp was -6.9 degrees..I did to much R12 in the system..
    Thats my aircon same as on VB VC as far as i know its a 1984 Opel Monza as i am from Europe,if i was u:
    Buy some R12 in the USA on ebay with a refill hose and fill it ureself,my aircon is working now for over 2 jears like it shut..
    I called a aircon company here in Holland and told my story:1984 Opel Monza-Harrison A6 compressor-R12 aircon isnt working can u fix that...there answer was yeah for 1000-2000$ we have it running for u sir,i thought for those 1000/1500kays a year that i drive with that Monza i dont need aircon.
    Than bumped into a old classmate of mine who works with aircons and told him my story and he told me:
    As long as there is a bit pressure on the system,means,no air from outside gets in the system means no moistures gets into the system,filling it to the right amount of freon shut be okay on those old system,as no system is 100% leak free,and those old cars are pretty well build,just fill it up and give it a go he told me.
    Than i searched the inet for R12...and there is plenty of R12 in the USA and some sellers shit it worldwide:
    R-12 Refrigerant 14 oz can Case of 12 | eBay
    R12 Freon Chargette 14oz cans | eBay
    R12, Refrigerant 12 COLLECTOR CAR KIT w/STOP LEAK | eBay
    For like 200$ u shut have the aircon going at best capacity.....
    Atleast that what i did,and its still going after 2 jears..
  1. [VIC] Heaps of VT - VX stuff, a few headunits and stuff
    By GILLO in forum Parts And Other Items For Sale
    Last Post: 21-09-2009, 02:41 AM
  2. [VIC]S.E Surburbs] 5 LTR stuff and other stuff
    By h0Ld3n`VN in forum Parts And Other Items For Sale
    Last Post: 24-06-2008, 09:58 AM
  3. Smits Cleanout Sale (VT-VX Stuff, Other random stuff)
    By SMIT in forum Parts And Other Items For Sale
    Last Post: 05-03-2008, 10:43 PM
  4. F.S. heaps of vk stuff. 308's ect ect ect some 6 cly stuff too!!
    By ported in forum Parts And Other Items For Sale
    Last Post: 10-05-2007, 07:36 PM
  5. RIMS< VN STUFF<VY STUFF<ETC****
    By UNEQVN in forum Parts And Other Items For Sale
    Last Post: 17-10-2005, 04:58 PM
