Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By ari666
Thread: VK 253 with HQ engine mounts
    vr v6
    Aug 2009
    Default VK 253 with HQ engine mounts
    Hi all, I am trying to find any info on bolting a 253 into a vk with HQ engine mounts.Has anyone tried it?I know there should be problems with the firewall and sump clearances ,but how much?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Sump, and oil pick up (most likely dipstick too) need swapping out,
    Engine mounts not sure on,
    Re-read O/P so, this last line of reply is irrelevent... lol.
    VH SS
    May 2009
    Toowoomba, Qld
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    They will fit. I think motor will sit a bit forward more. Don't hold it to me. Cheers Jason
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    Zeussy's Avatar
    Dec 2008
    Central Coast
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Use VB-VT engine mounts what ever you can get that will suit the accessories you have bolted on tot he engine in the positions your have
    as others have said you need a commodore sump
    you will also need to comply to the emissions of the car or not tell the RTA/dmv/vicroads etc that you swapped the engine
    scott
    VB SL/E
    Dec 2008
    The rubber mount itself is interchangeable but the bracket that bolts to the chassis is not, as above you will need VB-VT brackets, sump, oil pick up and dipstick.
    Be aware that a red non pollution motor will not comply with VK ADR rules such as carby, inlet manifold and heads.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i am hearing a number,,, it is,,, 27!!!!
    the magic 27!!!!????
    OMFGLOL. um yeah so 27 says if you are going to the effort of 253, you may as well go 308. itll cost you an extra 500 bucks
    vr v6
    Aug 2009
    I got bored and started to put a bare block plus gearbox in today,it fitted with ease(about 60mm further back) but it looks like the steering might be a problem when i put the heads/extractors on.How close is the stock sump to the crossmember normally?
    vr v6
    Aug 2009
    27? I want to spend $0 on my commodore and use the parts i have.I allready have two 308,s in my torana,s
    ari666's Avatar
    1966 impala
    Mar 2009
    k. well 27 says you cant have a 253.
    you cant argue with 27
    (god, i hope its 27, not 23....)
  1. Engine mounts?????
    By rocket0000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2010, 04:48 PM
  2. Engine mounts
    By 6 shooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2010, 10:06 PM
  3. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  4. engine mounts
    By commnz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2005, 04:28 PM
  5. Engine mounts
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 12:21 PM
