Results 1 to 6 of 6
Thread: VK Tacho to Blue Motor
    VK 202
    Mar 2010
    Adelaide Hills
    Default VK Tacho to Blue Motor
    I have been getting some work done to quell the rust and leaks in my VK's boot. While she’s been out of action I’ve decided to finally look into fitting a stock tacho in favour of the infamous vacuum gauge! I took the cluster out and have had it re-conditioned (looks near new!).
    The new cluster housing is from a Berlina, so it has the necessary tacho connections for the plug. The fellow who did the work for me, has marked which prongs are associated with the tacho. It seems my car’s loom has 2 wires that correspond with the tacho prongs on the cluster (1 is a darker green, the other brown). However being my girl is the basic model, she came factory with a vacuum gauge. Does anyone know if these wires are connected? I suspect at least one goes to the EST computer?
    I am also wondering; since my beast has a Blue 202 instead of a Black, the EST computer is not being used. It is still plugged into the loom however. My assumption is that the tacho wires (if connected) are/is still attached to the EST. If I were to cut one of these wires in the loom (near the grommet in the engine bay) and run it to the coil, would there be any issues with the EST or general running of the car? Also are the return wires usually brown, because the other wire associated with the tacho is brown?
    Cheers.
    Mr 84.
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    I have had the same problem but now have it sorted.I used a VB 6 cylinder sports dash with the 6 cyl tacho and hooked it up and it didnt work. I dad to run 2
    wires from the coil and an earth and connect them where the 3 prongs go into the dash. Top wire is NEGATIVE, Middle wire is EARTH, Bottom wire is Positive.
    I used a screwdiver and pryed the clips out where the prongs go in the dash and then solded them in. It seems that cars were not fitted with wiring for tachos if fitted with vaccum gauges. Hope this helps.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    All I know is one will go to neg on the coil
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VK 202
    Mar 2010
    Adelaide Hills
    Ah cheers. I hooked my tacho up recently to test it and had the same thing - nothing happened. I've been looking around for wiring diagrams and haven't found quite what I need yet. Upon talking to the speedo man, I was told the Brown wire is the one associated with the tacho. The green wire is for the temp gauge, he made the mistake of writing a 'T' by both prongs without distinguishing. So to my understanding what I need do now is just splice the brown wire and run it to the coil! Thanks, any other advice welcomed!
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Quote Originally Posted by Mr 84 View Post
    Mr 84.
    Hey mate, Where did you get this done? I need my cluster fixed up BAAAAD!!!!
    Cheers, James.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I have a sneaking suspicion that if you plug it in it will work as i also had a look at my wiring but got rid of the 202 before i plugged the dash in.
  1. [SA] White dial 4" tacho with blue backlight and shiftlight
    By L67 Calais in forum Parts And Other Items For Sale
    Last Post: 13-11-2009, 07:24 PM
  2. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  3. [NSW] F.s- tacho, diff, oil breathers, turbo timers, holley blue
    By BLOW6 in forum Parts And Other Items For Sale
    Last Post: 17-02-2009, 04:38 PM
  4. 253 V8 blue motor
    By xrsist in forum Parts And Other Items For Sale
    Last Post: 20-10-2008, 12:41 PM
  5. 2.8L blue motor, how much??
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 07:15 PM
Tags for this Thread
