hey just a quick question thinking of converting the vh back to good old petrol now im gonna get a vn/vp fuel tank wondering if the neck on the vn/vp will work fine on the vh or not thanks
it will but it wo t bolt straight in it will need to have the bend increased and shortened
scott
dunno if sedans are different but i have a vs one in my wagon un modified.
Current project VH SL SEDAN 202
http://forums.justcommodores.com.au/...-83-vh-sl.html
Last project VH SL WAGON L67
http://forums.justcommodores.com.au/...h-wagooon.html
The fuel filler neck is longer. It is extended by a rubber hose. Just push the neck down the hose. The fuel pump is in the tank and it has a fuel line return. Other wise bolts straight in.
hey guys im half way through doing a 304 conversion in my vh and am putting a vn fuel tank in and was just wondering if all the wiring is the same for the fuel gauge ect. cheers
If in doubt......FLOOR IT!!!
the VN has a different plug on the sender. Just cut the VH connector off and solder a VN one in it's place
sweet as thanks man .... haha puttin the engine in is the easy bit its the million small jobs ya gotta do to make everything run smooth... but guys like you are making it easier cheers
